My first forged knife
I finally made my first knife - a little skinner - out of one of my grandfather's old stone chisels. I can only guess it's 1080 or something of that family.
Sorry about the pic links, but I could not get any form of Imgur link to work to post the actual pictures. I registered a long time ago, but only started reading the forum a few weeks ago. I came across a pipe forge I never finished from about 8 years ago as I was moving stuff into my new farm shop. I finally finished it and found a new winter hobby, as I gave up skiing due to being too old to be a maniac. It seems only proper to now buy a membership here.
I made the forge from a 10" steel pipe, homemade insulation and made an entirely inappropriate propane burner for it. The forge insulation melted. So I bought Kaowool and satanite, and detuned the burner. I welded some scap angle iron and closed the back in with sliding firebricks. I'll get some more for the front. My old Carhart sleeve only caught fire once.
Melted forge
Since I was fortunate enough to inherit my grandfather's 125# anvil, leg vise and shope vise (he was a mason, plumber, etc.), I had a head start there. I bought a HF cross pein hammer and ground the pein down so it was usable to move steel instead of dent it. Someone at work gave me some flat tongs years ago, which are sometimes adequate. Welding to some square bar is much better. I've had a HF 1x30 grinder for years, which has been abused by working it way above its pay grade with all sorts of farm equipment repairs and fabrication. I just got the Grizzly 2x42, which is definately a few steps up. I'll be breaking that in on some 52100, which I cut up from scrap machine bearings I had laying around.
So I pounded out the chisel, and cut two blanks out of it. I shaped it with an agle grinder and flattened it with the HF grinder. I hardened it in Canola oil, as that's what I could get my hands on other than the buckets and buckets of used diesel oil I have. Then I tempered it 2x at 400 for two hours. Then I made the other blank into a similar knife for my neighbor. His came out better, of course.
Rough blades
I didn't polish the blade, but sanded it to my patience limit of 320 grit. (The next one will spend the day in my brass tumbler.) Then I blued the steel to protect it to a reasonable degree. I did not burnish it, because it looks cool as is - almost like monotone case-hardened. I had sawed off a chunk of maple burl years ago, so that was rolling around the basement. I used a 30 year old can of concrete, brick and wood waterproofing stuff for the wood finish. They don't make it anymore. Probably illegal now. I think it came out ok, and the steel is hard and sharp as f*(k. It takes and holds an edge really well. As you can tell, I didn't spend a lot of time on detailing.
Finished First Knife
And then I made a Kydex press from a hunting seat pad, scrap wood, and a hinge. The riveting was unsuccessful with a homemade punch and mini ball pein, so I ordered a rivet setter to finish my neighbor's sheath.
Kydex Press
Thanks for any comments.
Good for you!!!! Nice job.......Keep up the good work and keep sharing them with us PLEASE🙏.....
Nice work👌
I made another knife for my brother for Christmas. I used a chunk of an outer race of a bearing, presumably 52100. It was finicky to soften, and I soaked it in my forge at about 1650F or so for as long as I could stand there, ~ 15 minutes, and let it cool down in the forge. I did that a few times. I was able to drill tang holes through it. Then I heated it to just over magnetic and quenched it in Canola oil. I did that 3 times, and finally got it very hard. I used the 1x30 to rought grind it and the Grizzly 2x42 to finish up. I expect my belt supply for the 2x42 to be delivered today, so I can do the work on that. It's so much more controllable than the 1x30 on ludicrous speed.
I made the scales from some more burl, and finished the blade with some blueing. I didn't spend much time polishing the blade because I got stalled with the heat treating difficulties, and only took it down to 120 grit.
My 5th knife. I still have to change my finishing order. Blade before scales installed.View attachment 2756078
You should always finish the blade before attaching the scales! Just tape up the blade really good to keep from getting scratches on a nice finish :) Looks great! A little constructive criticism: the pins should be centered on the handle, and I like when the front pin is the same distance from the front of the scales as the back pin is from the back. Can’t wait to see your next one!
Thanks for the advice. I offset the rear pin location for distance from the lanyard hole. I agree it does look rather odd, but it's unique. I made it for a buddy of mine, who is going to beat on it appropriately.
My next knife is going to be a Kephart-gone-chopper style knife for use in trail clearing along with my chainsaws and machete. I have some old bearings I'm going to use. Hopefuly I'll get lucky again and be able to normalize and harden the 52100 properly with my forge.
