I can't speak for all GECs...but the knives I own/owned/held have all been a little different. The new 14 run has been consistently about a 7 pull...so a little on the firmer side. The 43 Oregon Trapper I have is probably more like a 4-5. The 15 single spearpoint blade was about a 5. The 44s were a little firm maybe a 6 pull.Is a firm open/close typical of GEC's ?
Thanks for the info waverave.I can't speak for all GECs...but the knives I own/owned/held have all been a little different. The new 14 run has been consistently about a 7 pull...so a little on the firmer side. The 43 Oregon Trapper I have is probably more like a 4-5. The 15 single spearpoint blade was about a 5. The 44s were a little firm maybe a 6 pull.
It does vary a bit but the 6-7 range is typical in my experience.
They seem to be all over based on pattern mostly, but sometimes vary by the run (i.e. the 2018 version of that pattern might be different than in prior years). The bullnose in particular is pretty tight.Is a firm open/close typical of GEC's ?
If the pull is stiffer than the pen blade on the Whaler, I would never be able to use it.The bullnose is the stiffest pull I’ve had and I’ve handled about twenty or so patterns now. A patina will probably make it pinchable though.
I've never handled a Whaler, so I couldn't say. Mine is stiff, but not so bad that I slip off.If the pull is stiffer than the pen blade on the Whaler, I would never be able to use it.
