- Mar 28, 2013
Alright, so here's my review for my House Handle order (now keep in mind I've yet to use any of these in a hang yet). My order was as follows (top to bottom) Two 32" SB handles, hand select no lacquer, two 30" SB hand select no lacquer, two 30" DB hand select no lacquer octagonal, two 28" SB hand select no lacquer, and two 28" boys axe hand select no lacquer.
In terms of overall grain orientation they're pretty spot on aside from a few (which can be seen down below) and some cases of runout but they don't look like the runout runs very deep and I should be able to shave it down enough to minimize the problem. The rings were a bit spotty, some showing they came from fast growing trees where some had a rather slow growth (also the occasional false growth ring), I'd have rather seen it all be slower growth but what can you do.
That brings me to the second point: Thickness. the regular hand selected handles (non octagon) ran 22mm in the center of the handle, that's darn thick. There was also quite a bit of taper in width to the handles but that means I've got more room to shave it down and get it exactly right so that doesn't hurt my feelings too much. The octagon handles however are a nice slim 15mm, they feel really good and if one didn't want to bother shaving down the regular handles, the octagon handles would be the way to go as you can simply round off the corners.
In terms of overall shape, it varies. As you can see sometimes the palm swells are a bit off kilter but nothing that poses a major problem. Aside from the thickness, the curvyness of the handles varies too (again not a big problem for me).
I only had one handle that was heartwood-sapwood mixed which surprised me but one of the 32" handles did show some staining and both of the DB handles had checking in the butt of the handles (I could probably get my money back on those) and on the sides of one of the 30" SB handles but those are being reduced in width anyhow so I'm not too concerned.
Overall I'm impressed with the order, especially for the price. I believe it was around 140 shipped for all 10 handles which is cheaper then buying the lacquered up glorified 2x4's from the local hardware stores so I'm not complaining. Will it replace a quality slim and curvy (or even straight) vintage handle? Heck no. But they're a great platform to set yourself up with a nice handle.
