So I was lucky (and quick) enough to get a WWII by Vim Bhadur Kami during one of the Christmas specials. The blade is beautiful. I hope to test it this weekend, but had a few questions.
There appears to be some heavy oil(?) on the blade protecting against rust. After I test the blade (by whacking a few logs) what should I put back on the blade to keep it stored until I can use it again, probably in the spring? I have tuf-cloth and tuf-glide, would that be enough or are there suggestions for something else. Is there anything I should put on the wood handle?
Aligning the edge. Does anyone one use something other then the chakmak?
Sharpening. In another post, Salamander42 mentions sharpening the blade on his leg with a mouse pad for the convex edge. What type of sandpaper is glued/taped to the mouse pad?
Thank you for your help. As soon as I get her out I will post a few pics.
First of all, Congrats on your new khuk
! The WWII is a fantastic blade.
As far as oiling going, you can do a number of things. Tuf-cloth seems to work just fine. Also, mineral oil (or baby oil if you don't mind the scent) is a cheap and easy way to keep you blade rust free. Some people store the blade dry. It just depends on what your climate is like. At home, I can store my khuks unprotected for months and months at a time. However, the ones that I keep here at the office need constant case since I work around Chlorine, and it pits the steel like crazy.
Another thing to consider, if this is going to be a user, then you might just forgo the finish all together. It's going to get scratched, dinged, and marred. If you want to protect the blade, yet give it a uniform finish, then you might consider putting a patina on it. Basically, you'll just be doing a mild etch with acid (usually acid fruit juices work fine) that will give the blade a nice satiny gray color that will stave off some of the rust.
As far as chakmas go, they are hit and miss in the hardness and length department. From what I understand, Yangdu is getting a message to the kamis that they need to make them a little harder so that they are more useful. I actually use a couple of butcher's steels to align my edges. I use a toothy one to sort of hog off a bur, then I use a smoother one to push the steel back into alignment. I also have a couple of really hard chakmas that I use after that to finish it up. Then I just give it a good stropping on some polishing compound loaded leather to bring it all the way back....or you could just stop after the toothy butcher's steel
As far as convexing the edge, many khukaholics will invest in a belt sander to make the work much easier. For me, I have nothing but time here at work in my office season, and no real space for a belt sander in my garage (I would if I cleaned the danged thing out). The best way that I have found to convex and polish an edge is to start out with around 400 grit sandpaper and move up from there. Just keep stropping the blade until you get it as sharp as you can, then move on to a finer grit. Some guys go up to 1000+. I'm lazy and usually stop at 600ish. After 600 grit, I just move on a leather strop to polish the tooth off the edge. It'll shave hair, but not split it.
Also, keep in mind that keeping a khuk razor sharp is not really recommended for a heavy user. It'll take and edge, and it'll keep and edge. However, the thinner more polished edges will dull and deform before a good sturdy "axe sharp" convex edge.
Once again, Congrats and welcome!
:thumbup:
