- May 21, 2014
Hello all!
I just completed my first knife, and boy was it a learning experience. I've been a lurker on here and Reddit a while, but just recently made and account on BF.
Here's some info:
Steel: 1/8" 1084 from Aldo
Grip material: 1/4" Padauk from Keim Lumber (great place in Ohio with a ton of selection and odds and ends)
Pins: 1/4" Brass rod
I don't have a lot of tools, so I will detail the build. As this was my first knife, I figured 1084 would be a good steel to start off with. I ground out the initial shape with an angle grinder, and then refined that edge with a bench grinder. Once this was accomplished, I beveled the edge with a homemade jig, which I made in reference to Gough's knife jig. I then drilled the holes for the pins with a drill press, and a few extra holes for the epoxy to set in. After this, I sanded the blade portion with 120, 220, 320, 600, and 1200 grit sandpaper. I sanded the tang with 120, but left it rough to help with epoxy adhesion.
I then hardened the knife in a fire, checking for non-magnetism. I quenched in oil, and then did two rounds of tempering in my oven, keeping the temperature an average of 400ºF (my oven sucks and would either set itself to 420ºF or 380º and not stay right at 400ºF). I had a remote thermometer that I used to monitor temperature. I expect the hardness to be around HRC 55-58. Who knows though, as this was my first time. I'm reasonably confident in my methods, and have no real way to test the hardness. With use maybe I'll see whether or not it got too soft/too hard.
After this, I cleaned off the scale, and sanded the blade again, and then finished with some black, white, and red polishing compounds. I then cut out the grips, trying to keep the grain of the wood the same direction as the heel(?). I fitted the pins, and then epoxy'd the entire thing together. I did a final sanding of the grips to a comfortable shape, and then did two coats of Tung oil.
I sharpened it as well, with a crappy sharpener. I am going to order a waterstone (1000/6000 I think) here soon.
Overall I am extremely pleased. I could have never imagined I could make something like this (I never took shop class!). There are nicks and scratches here and there, and some other annoying spots, but for a first knife, I am really happy with it. I ordered 48" of 1084, and I have some curly maple and some purple heart too, so expect to see more from me! Maybe I can post some knife designs so I can get some feedback.
Anyways, have a look at the photos and tell me what I did wrong
http://i.imgur.com/KrRnYnJ.jpg
http://i.imgur.com/PltmHjN.jpg
http://i.imgur.com/r70WoIs.jpg
http://i.imgur.com/SXNnZWk.jpg
http://i.imgur.com/h5aDvSt.jpg
Here's some info:
