- May 8, 2014
I've lurked for a while but never posted. I don't know enough to give advice and most of my questions are answered through other peoples posts. So I've never really needed to post. But that makes me feel like a mooch. So I figured I ought to share something. Mainly I want to say thanks for all the knowledge shared on these forums. My first knife has some shortcomings but it's significantly better than it would have been had I not had the info you all provided. So thanks!
Blade Material: 1095
Handle Material: ??? Actually not sure, some scrap of hardwood I had laying around the shop
Blade Thickness 3/16 inch
Blade Length: 4 inches
Blade Grind: flat grind
I think I'm happy with it given its my first attempt. The plunge line at the ricasso turned out a bit rough. Also I'm unsure of my heat treat. I followed the advise other posted on the forum for 1095 but I'm not sure I had the heats correct. A kind older gentleman gave me his old pottery kiln and I purchased a cheap temperature controller and sensor off ebay and wired it up to use as a heat treat oven. The setup seems to work great but I've never tuned the temperature controller to the kiln. I worry what I was reading was not the actually temperature. Not sure how to tune it actually. I should have checked for non-magnetic which I didn't. Now I'm kind of kicking myself. Oh well, lesson for the next blade. Seems to take and hold an edge pretty well, but I've not had a 1095 blade before so I'm not sure what to compare it to.
