- Mar 2, 2017
Thank you. I need to find out what type of belt to use to get a good finish.Very nice. Looks like a great kitchen knife.
9 inch blade, Brazilian cherry woodWhat are the dimensions?
Is the handle walnut?
2 inches wide9 inch blade, Brazilian cherry wood
Chef knifeLooks like a nice kitchen knife. So, what is it?
Most of my kitchen cutting is done with a smaller knife, although I have an assortment. I wouldn't concern myself with the finish. Keep it sharp. Use it.
No. That is the kind of advice I'm looking forNice knife!
Have you ever tried a cork belt with aluminum oxide polishing compound?
Okay, what you do is get a 400 or 600 grit cork belt and hold a piece of scrap mild steel against it for about 10 minutes to break it in. Then hit it with the polishing compound and finish grind your blade. You will get an excellent finish and the belt will last you for years!No. That is the kind of advice I'm looking for
Okay, is that for the entire knife or just the bevelOkay, what you do is get a 400 or 600 grit cork belt and hold a piece of scrap mild steel against it for about 10 minutes to break it in. Then hit it with the polishing compound and finish grind your blade. You will get an excellent finish and the belt will last you for years!
I believe I knew that already.... you didn't say you made this knife, so I assumed it was a factory knife. I still assume it's a factory knife until you say it's not.Chef knife
