Appreciate it. This forum has been very helpful.Congrats and welcome to the forum! We never forget our first ones.![]()
Thank you, I wish I could have gotten the lines a little cleaner, but I'm happy with it for a first project.Great start![]()
Well done, if you want to know a little trick for cleaning up edge bevels, I found Aaron from Gough custom knives home made file bevel jig very helpful. They are easy to make and cheap to set up. use your grinder to do all the hard work then use the hand file jig to get the lines perfect, you can also use it to completely set the bevels from scratch but that takes quite a while. It will clean up your bevel in about 5 mins though.
Here is Aarons jig build and demo
I built one myself they work very well.
Thanks, I'll give that a try on the next one. Is this more for files across the length of the blade or back and forth? This first knife was such a short blade 2.75" that is was tough. My next one I'm working on is a 7 inch drop point with a 3 7/8 inch blade, seems a little easier to work the longer blade.
