- May 21, 2011
... I like it.
I went with a SNG CC because I think it offers the best size for carrying and cutting. The choil makes the cutting edge a lot shorter but I prefer 3-3.5 inch blades.
Pro's:
Looks good
Feels good in hand
No horizontal blade play
No lock rock *vertical play*
Sharp out of the box
Strong detent *blade won't open accidently*
Con's:
Blade is not centered *almost though* I could/will fiddle with it later to see if I can adjust this
Fit & Finish is good but there are some rub marks *not scratches, or at least not deep enough to go through the blade coating* on the blade. I'd say they are when the blade was stacked on top of others or placed on any ol' thing. Doesn't seem like they were placed/rested on cloths if you know what I mean.
Blade showing through lanyard holes ever so slightly. I don't like lanyards personally but a con is a con. Maybe they didn't sharpen the blade down far enough. Almost not a con for a user knife.
Will have to give it a few good *hundred+* flicks to see where the lock bar settles. So far it is solid in that I don't have any blade play and I'm not worrying that the lock bar will disengage.
If I give it a hard opening the lock bar is at 45-50% but if I open it normally it is at 35-40%.
Is the knife worth the price? Sure, if you have the money. I don't see myself selling this knife.
If this helps good and if not then here are some pics to look at.
The Arctic grey is not as white as the pics suggest.
Pro's:
Looks good
Feels good in hand
Con's:
