My Gayle Bradley arrived today! (lots of pics)
Banner day here! The Gayle Bradley Carbon Fiber has been on backorder for some time, so the excitement boiled over when it showed up on my doorstep this morning. I attacked the shipping box with my Stretch CF EDC immediately. Wow, the Gayle Bradley is a gorgeous piece of work and quite substantial. The carbon fiber scales look and feel great. It even has a gold Spydie on the clip:
Very cool. Had to open the CPM M4 blade right away:
Kristie described the Gayle Bradley as a beefier Stretch, and that's exactly what it feels like. The Bradley weighs in at 5.5 oz compared to the Stretch CF's 3.9 oz and you can feel the difference. The GB also sports thicker stainless steel liners and CF scales, making it quite rigid in the hand:
This image hopefully shows how the liner has been cut-out to save weight, which has dropped from the published 5.5 oz in the original production run to 5.1 oz in the current run:
The above image also shows how the GB has a completely open spine, allowing thorough cleaning after heavy use without disassembly. Here you can see the open vs. closed spines of the Bradley CF and Stretch CF as well as more of how the Bradley's liners have been lightened:
Gayle Bradley's Weatherford Texas logo displays proudly on the blade:
Here's a comparison shot of, from top to bottom, the Endura 4 Black Blade CE, Gayle Bradley CF, Stretch CF, and Delica 4 CE:
Although much wider than the Stretch CF, the Bradley's handle reaches only 1/4" longer. The Bradley's 3-7/16" blade compares favorably with the Stretch's 3.5" blade.
Overall, the Gayle Bradley feels very substantial and looks ready for work. Gayle Bradley offered on this forum that he has carried his for about ten months and the CPM M4 has served him well with no issues. Although not stainless, the M4 only needs occasional care with a little silicon or other preservative on the blade to maintain it. I personally use a silicon gun cloth on all my knives, which works great and doesn't run or pool.
The Bradley functioned perfectly out of the box. It opens easily and the stainless steel Mike Walker LinerLock engages positively with a distinctive metallic snap. The lock bar sets a standard for robustness, being much thicker than others I've used:
If this one ever lets go, look up for the stars falling from the sky. The ergonomic handle fits my hand perfectly, with the curve under my thumb leading right to the jimping on the top of the Spydie hole. My fingers locate naturally and comfortably into the handle's purposeful shape.
Esthetically, the polished carbon fiber sports a weave-patterned surface for good gripping. The fit-and-finish from Taichung remains extraordinary. The large lanyard hole at the rear of the handle is piped for durability. Black torx screws hold the knife together and the clip can be set for tip up/down and right/left handed. The stainless liners stick out about 1mm beyond the CF scales for a great look as well as easy operation of the LinerLock. The thoughtful liner cutout opposite the lock also helps. I'm not a fan of LinerLocks in general, but this one works well one-handed without blood-sacrificing knuckles.
I bought the Gayle Bradley for outside work, hiking and camping rather than as an EDC. The thinner, lighter Stretch CF remains my EDC, continuing to serve with distinction. The Gayle Bradley will serve with equal distinction as a hard-use folder with a gentleman's look. Many thanks to Mr. Bradley and the Spyderco crew!
The more I check out the Gayle Bradley the more I think that I "need" one. Nice pics.
Regardless of individual preferences, the Spyderco Gayle Bradley has already earned its place in the Spyderco Hall of Fame as far as I'm concerned. It amazes me how consistent the Taiwanese MFG of the GB is with regard to fit and finish on the Gayle Bradley. It truly stands as one of Spyderco's baseline knives for overall quality and value. Period.
Oh, both liners are now drilled! Not so on the first run. Neither is drilled on the first run.
Yes, both are drilled. The pattern is a bit different on each side because of the liner lock - four uniform round holes on the non-lock side, three smaller round holes of varying size on the lock side.
I didn't weigh it, but it feels that heavy relative to other knives of "known" weight. The next heaviest knife I have is the 83mm Citadel at 4.8 oz, and the Bradley feels a bit heavier.
Hmm, I just noticed that on mine too. I have the first run with the full liners and no GB logo. Regardless of price, the GB is probably one of the nicest fitted and finished knives I've ever encountered. Everything about it is immaculate.
I sort of like the full liner for easier cleaning and as I carry the knife tip down the spyder drop is very easy with a little handle weiught.
But this new improvement shows how Sal and crew are listenning to their customers which wanted it.
The GB is such a great reliable workhorse. A true Gem in the Spyderline.:thumbup:
The only reeason I asked is because I thought the original, non-skeletonized models were advertised at 5.5 or something close. I would think you could save .5 to .75 of an ounce with the drilled liners.
Makes sense to me. Doesn't look like Spyderco updated their website with an update for the new liners. It's not a lot heavier than the Citadel, so it could be in the 5.1-5.2 oz range. KC lists the GB at 5.3 oz, but don't know from where that number came. Could just be a typo. I'll see if I can find a way to weigh it today or tomorrow.
Wow, what a good guess! I was finally able to accurately weigh the new Gayle Bradley with the liner cutouts tonight. It comes in at 5.1 oz. That's somewhat less than the first run's 5.5 oz w/o the liner cutouts. I'll edit the original post to indicate the new data.
Tanker Bob -
If you intend on using the GB you will be very satisfied, indeed.
Fit and finish is very good on this knife. It aligns very well when reassembled (most knives I've had have a bit of a fidget factor, not so with the GB).
I was using it pretty hard as a woodworker and that mofo is a top notch work knife. The CPM M4 is nothing short of outstanding.
An absolute champ of a knife, IMHO.
For me, the GB is the flagship Spyderco.
Curiouser and curiouser. Mine has the full solid liners with the GB crest and is only marked 'Taiwan' without the 'Taichung'.
The GB is a hall of fame folder period! Not just in the Spyderco book, but in the whole book! It's in my pocket right now, sweet grey patina, EdgePro polished edge and wicked sharp. The factory edge angle is the most acute I've found on a production folder I think.
I have taken it down and it can take a bit of doing to get it back to centered but a little trial and error is good for you, helps you learn.
Love this knife.
Interesting mix of blade etchings. From a number of comments, some early Gayle Bradleys seem to have had just "Taiwan" and the Spydie logo on the blade with solid liners. At some point, Mr. Bradley's "Weatherford, TX" logo appeared on the blade, still with full liners. It seems that the lightened liners were added in the latest production run, which cut the weight from 5.5 oz to 5.1 oz, along with the "Taichung, Taiwan" origination etching. My recent run Bob -T. also has the "Taichung, Taiwan" origination etched on its blade.
