- Aug 1, 2000
Hello All,
I have an idea for a square wheel grinder and I'm looking for some constructive
criticism to help direct the design. I'm trying to offer an inexpensive
design that the typical home shop guy (gal) can use operating on a home
shop budget.
<center>
<img SRC="http://www.geocities.com/beaumontmetal/sq_wheel/rendered.gif" NOSAVE BORDER=3 height=401 width=551>
This is the basic concept for a 2 X 72 beltgrinder.</center>
Simply bolt the square wheel assembly to the front edge of your workbench.
Your motor can be mounted on a hinged plate/board so that it can fall back
to tension the belt. Maybe add a spring or clevis for more tension....?
I didn't draw the motor mounting/belt tension details.
Similar to <a href="http://www.caffreyknives.com/wilton.htm">Ed Caffrey's
page on his Wilton modifications</a> , I made the platen so that it is
interchangeable with different lengths and widths...and also adjustable.
<center>
<img SRC="http://www.geocities.com/beaumontmetal/sq_wheel/squarewheel.gif" NOSAVE BORDER=3 height=506 width=561>
These are the basic overall sizes.</center>
The two rollers are solid aluminum at 2.5 dia. Every thing else
is angle iron and aluminum plate.
I think I can offer this assembly for just under $200. You would
supply your own motor and fit it with a drive roller. (I can supply the
drive roller of your choice also). Bolt it all to the work bench
top, fiddle with the tracking by moving the motor around...and bammo! your
off and grinding.
So whatta ya think?
add a tool rest?
Bag the whole idea?
stick with wheels only?
Seriously though, please let me know your thoughts and ideas.
Truly,
Rob Frink
<a href="http://www.geocities.com/beaumontmetal/index.html">Beaumont
Metal Works</a>
shop budget.
<center>
<center>
off and grinding.
So whatta ya think?
add a tool rest?
Bag the whole idea?
Truly,
Rob Frink
Metal Works</a>
