moparsbob
- May 6, 2014
I'd read about the Royal Nepalese Armory and the purchase of same by the Alanta Cutlery/IMA folks a few years back, before I discovered HI Khukuris and this website (Thanks to reading Larry Correia's _Monster_Hunters_ books where the protagonist mentions his HI Ganga Ram Special). So I decided that I should get one of the older longleaf khukuris before they were all gone, and I decided to go through IMA instead of Atlanta Cutlery, because I wanted to order a couple of other items from IMA, and they also had a "hand pick" option, which wasn't available ordering through Atlanta Cutlery (at least, I didn't see one). My order arrived a few days ago, and I just got all of the nasty old cosmoline (or whatever it was) removed from the longleaf. It has numerous scratches on the blade, some pretty deep, and various forging marks. The handle is only 3 1/2" long on the bottom edge, and 3 3/4" on the top, with only a partial tang and no metal buttplate. The ring on the handle is much nearer the butt, so that it falls between the 4th and 5th fingers when you hold it, not between the 3rd and 4th fingers like the HI handles. While the handle has some dings and chips, it is still very solid. So here's my piece of history:
And here's the inscription on the spine:
This khukuri is about 18.5" from the tip to the midpoint of the handle end, the spine is about 7/16" from the handle to the bend in the spine, and then tapers to about 3/8" at 1/3 of the way from the bend to the tip, to 1/4" at 2/3 and about 1/8" at the tip. The weight is 27.2 ounces. It did not come with a sheath. The blade is interesting in that it is sort of a T-spine from the handle to the bend, where the two lines of the sword of shiva are actually steps down, so while the blade is 7/16" thick at the spine, it is less than 5/16" immediately below the bottom line of the sword of shiva design. The blade is somewhat concave from the spine to the edge, but I wouldn't really call it a fuller. I would be very grateful if one of the Devanagari experts could give me a translation of the spine inscription.
