- Sep 23, 1999
We;;, thanks to Jimbo I had to pull out my Mora knife and play. For those who don't know of Jimbo, go to www.oldjimbo.com and spend a couple of hours reading the articles and enjoying the pics. SOme of the articles are by V-Shrake, and they are great to read too. But last night I was reading Jimbo's articles on Mora knives and how he would sharpen his moras to get into the good steel.
A few months ago I bought a Mora (KJ Erikson, sorry for the spelling). It has a red handle, single guard, and a 3.something inch carbon steel blade. It cut VERY well as is, and even more so when I stropped the edge. That was on light cutting. I decided to cut a square hole through a piece of basswood I've been doing varios things with while watching t.v. While whittling that hole, I was reminded of Jimbo's articles and I looked more critically at that Mora. Many Moras come very polished, but you can see distinct grinding marks. It looks like grinding wheel marks in the steel, that rrun on the edge bevels. Now, Scandinavian blades have a primary bevel that is also the edge (the so called zero-edge bevel, or scandinavian grind, or puuko grind). My Mora had damned near that, but with a tiny secondary bevel. I decided that I would take my mora to my waterstones and scrub away until I had a true zero grind. THis would also remove any grinding marks, which is a good thing. Wood cutting tools perform better when the cutting surfaces are flat and polished, so i figured I could take care of the grinding marks and get my first true zero edge grind all in one sitting! And if I ruined my Mora, well, I was out $11. Worth while for my experiment!
A great benefit of having the primary grind as the edge is the ease of sharpening. No jogs are needed to get the perfect bevel! In fact, I think it is on Jimbo's site or Kellam Knives' site that they say the Scandinavian style blades have a built in angle jig! All you do is lay the blade on your stone on the flat (unground) part of the knife, then tilt the knife until the primary grind is flat on the knife. In other words, these knives are saber-flat ground, so you lay the flat upper portion of the knife on the stone, and then tilt it until the ground part is flat on the stone.
I think it took me 10 minutes to raise a burr! Keeping things flat was tricky for me on the curved part of the blade near the tip, but practice will make perfect. Eventually I got a nice even burr from both sides of the knife. Then I switched to my 4000 grit hone and polished away. After that, an nice stropping session in front of my t.v. had the edge screaming sharp! THis is the sharpest knife I have ever handled- seriously!
This knife now cuts like a demon, thanks to the relatively thin steel and zero edge grind. Resharpening will always be easy, I don't have to fiddle with finding the edge bevel, and I can keep this knife this sharp until I sharpen away the whole knife. Typically, when we use knives that have secondary edge bevels, eventually the primary grind has to be reground as the steel has become too thick. With sharpening scandinavian-style blades, this isn't a problem as you take care of it as you sharpen.
There is a downside to my experiment- aesthetics! The primary bevels aren't nice and pretty anymore. I believe that as I practice more with this blade, I'll be able to remedy that. Ideally, I should have spend a little more time on my 800 grit stone using lighter pressure to help remove the deep 800 grit scratches. And, I would love a 1200 grit stone to use between the 800 and 4000 grit stone. In short, I think you could easily preserve the good looks of the bevel. Of course, that first tree limb you cut through using a baton (read Jimbo's site for the technique, as well as reading Mors Kochanski's Northern Bushcraft. ) will scratch the knife anyways.
The edge isn't as tough as the edge on my AFCK anymore, but it sure cuts better! For a knife that will cut meat/softer woods/vegitation/rope/etc, I think a zero edge grind is awesome! Where a secondary bevel would be good is where toughness of the edge becomes imcreasingly important- working around bone, hard woods, for "fighters", and chopping tools.
If you haven't tried a true zero edge bevel knife, I suggest gettin gan inexpensive Mora or a Schrade Old Timer if you want a folder and doing what I did. This makes for an inexpensive experiment and I bet you'll like the results. And I take no responsibility if after doing this experiment you look a little less fondly at all of the thickly ground utility knives out there! Blame the Scandinavians!
Actually, dont! They have sharp Viking swords to poke you with if you make 'em mad!
