- Aug 25, 2001
The Fulcrum is a big folder but it works fine for me in the optional belt sheath. It is a bit bigger than a typical multitool. I have been carrying and using the folder as a utility knife just about daily since I got back from the Blade show. Most of my cutting these days involves chopping up boxes and other junk from our recent move. It works fine though the thick blade makes it a little harder to get through cardboard than a thinner blade. On the other hand, the handle is big enough that I can securely grip the knife and not get tired even after a lot of cutting. To answer the first question, I'm finding the ER knives to be very well made and well designed. I haven't used the Col Moschin (fixed blade) much but when I did I was very impressed with the knife's handling and I especially like the very pointy blade tip. Quite useful and I will be interested to see how it holds up in the long-term.So what do you think of the Extreme Ratio knives you own? How often do you carry the folder? Do you find it too big or anything?
Interesting question that has caused me to think about this quite a bit. "Perfect" is rather subjective and, I think, depends on the price point of the knife. The Day Hiker I got from her early this year is a using knife that goes for a bit over $200 and is perfect at that price. The Dokuga is flat out perfect and she probably had it underpriced. The Mega Tac Stinger is closer to "good" or "very good" however this was an experimental knife that I bought off her table and I knew exactly what I was getting for my money.I have often thought of getting a Tomey Stinger, they look very nice for a relatively low price, is her F&F perfect, or merely good?
Looks like Frank got us covered with the picture of the Fulcrum lock. What we have in this lock are two thick slabs of metal butting together. How thick is it? Forget measurements, take FOUR pennies and stack them together. Mine locks VERY tight with no perceptible blade play. It takes a firm squeeze of the locking bar to unlock the blade so there is nothing wimpy about the lock bar leaf spring. Comparing it with other lock backs is easy. The Fulcrum has way more metal-to-metal contact in the lock than any lock back I've ever seen. My Buck 110 looks like a toy next to it. How does it compare with a Sebenza, a Strider AR, a SERE 2000, etc? It has way more metal-to-metal contact in the lock than any of these knives but I'm not qualified to compare a lock back to a frame lock or liner lock as I'm sure there is more to it than just the amount of metal-to-metal contact. I can't imagine any real-world activity where someone could actually break this knife at the lock or the handle. Still, it would be interesting to see what happens to the aluminum handle around the pivot when the lock is subject to extreme forces as this is only area when I can even imagine something breaking.What do you think of the ER folder's lock, does it seem stronger than others you have seen. If you had to pick a stronger folder, would you choose the ER over anything else, or are there a few folders you think seem stronger with a better lock? Like the Strider AR, Sebenza, etc.
