My kydex sheath is very loose.
You could try, but you might end up needing a new sheath. There was a thread here the other day about the same thing. One of the experienced Kydex benders commented about ways to fix this. Might be worth a look.
Hi Everybody,
Putting it in the oven will ruin the sheath:)
It is darn near impossible to completely remold a sheath after it has been finished, and some of the "Kydex" sheaths from major manufacturers are not actually kydex and react very badly to certain heats.
If you post a couple pics it would help a bunch.
You can also try these tips
with a hair dryer or heat gun, heat gun will work better but be careful to not over heat, overheating and kydex is very bad :)
You can heat a area on the back side of the sheath and make a depression that will put some retention on the blade and that will eliminate the rattle.
You can also heat the mouth of the sheath but that may take a few tries.
Report back and hope that helps.
