My latest knife: small skinner w/ beautiful curly maple!
Just finished this up last night. The blade is the 440C Dolphin Blade from Jantz. The handle is exhibition curly maple, also from Jantz. I took a gamble buying wood that I have not seen specifically, but they did not disappoint! The pins and tube are stainless. I finished the blade with a vertical brushed look using a grey scotch brite pad (I really need to get a SB belt for my grinder!).
The curly maple scales were sanded to 1000 grit then dyed using a thinned mixture of light brown and mahogany Fiebing's Pro Oil leather dyes. Afterwards, I put on a few light coats of spar urethane, but couldn't get it to lay down without marks. So I wetsanded it flat from 600-1000 and applied a final finish of Tru Oil buffing with extra fine steel wool between coats. It's still a learning process for me, but I think the final finish turned out great!
The lanyard is latigo lace with a wooden bead that I dyed the same color, then worked the finish back with sand paper to give it a complimenting look to the scales.
Sheath is made from 8/9oz veg tanned leather, dyed using the same lt. brown/mahogany mixture as the knife. I finished the sheath using a mixture of beeswax, paraffin and neatsfoot oil, melted in a double boiler and applied using a soft brush, then worked into the leather using a blow dryer. I really really like the hardness of this finish and will use it in the future. Final luster was done with neutral shoe polish and buffed with a microfiber towel.
The display/gift box was a request from the buyer as it is a gift for her dad. I wood-burned my logo into the lid, then sealed over it with urethane to prevent bleed through from the stain. Then stained and urethaned the whole box. Inside is lined with decorative beige felt.
I apologize for the pics, I really need to get a light box and a better camera :).
Any critiques and comments are welcome!
Thanks for looking!!
Very nice! The contoured fronts of the scales look good, that's an area many newer makers overlook. The sheath and other details are impressive as well. Keep at it, you're doing great.
Seems like you have a well-founded grasp on what makes a good knife, time to start grinding your own blades :thumbup:
Thanks James! Agreed, going to order up some belts for the 2x42 and some steel shortly :) I appreciate the comments!
Very nice fit and finish and the scales look great,and your leather work also---great job:thumbup:Regards Butch
Great Job on the whole package. the tooling on the leather looks similar to one I made from an old 12 spoint socket wrench. Did you make your own too? If so :thumbup::D
Jason
Jason and Butch, thanks!!
Jason, that tool is a Tandy stamp...I've seen the one you made from the socket (I think...Ive seen one done not sure if it was yours or not :) ) very creative using what you already had!
And you should sign up as a Knife Maker here on the forums. - :thumbup::D
Nice work, keep making them.
