- Dec 29, 2012
Materials used/Specifications
Construction
Blade shape
Lock
Pocket clip
Ergonomics
Steel
Deployment
Random points I want to touch on
What you get
pros
cons
I love this knife and would buy one again. It makes you feel safe and just a little BAD@$$! Why do I like it? What? You seriously didn't read all the stuff above this Sentence?
Griptilian open
Recruit closed (forgot to take an open pic, sorry
In hand pictures
Regular grip
Dagger grip
In hand closed
Other side
____________________________________________________________________________________
NOW GO GET ONE! AND GET IT FROM KERSHAWGUY! (Dave)
BLACK BLADE!
http://kershawguy.com/products-page/zero-tolerance/zt-0200/
SATIN BLADE!
http://kershawguy.com/products-page/featured-items/zt0200kw-stonewashed-blade-nib/
______________________________________________________________________________________
And that's that! Questions are welcome, ask away!
Cheers!
-Kirby
- Over all length is 8 3/4"
- The blade is 4" (DLC coated 154-CM)
- blade thickness is 0.156"
- The Handle is 5 1/4" long (3-D machined G10)
- The liners are skeletonized stainless steel
- liner lock
- four way positionable clip
- 7.7 ounces
skeletonized liners
Construction
- The body screws use T10 torx
- The pivot uses a 3/8" (SAE standard socket)
- stand offs
pivot and body screw
stand offs
stand offs
Blade shape
- good all around blade shape for just about everything (in my opinion) the recurve makes for a great slicer. I use it for yard work quite often and it flys through small branches and just about every thing else I can throw at it for that matter. the only downside to me is it's a bit of a challenge to sharpen, it would be fairly easy if I had a sharpmaker/lansky though.
*because of the recurve the actual cutting edge will be slightly longer than 4".
blade shape (sorry about the mediocre pic)
Lock
- It is a liner lock, and a very stout one at that. No blade play up, down, left, or right. Very smooth, and it doesn't stick. The detent is quite strong on my example (giving it a great flipping action)
Pocket clip
- The 0200 uses the standard Kershaw/Zero Tolerance clip. good retention. It Tends to tear up the pockets after awhile. Over all it's a great clip.
clip side view
clip front view
clip front view
Ergonomics
- like most Ken onion design the ergonomics are excellent, it really locks into the hand and is quite comfy. The texture on he G10 along with the thumb ramp/jimping really help keep it in your hand. I've heard some people find the choil uncomfortable, I haven't noticed any discomfort and I would guess its more due to bigger hands (which I do have so maybe I'm just part of the minority)
Steel
- The steel is 154-CM. good edge retention, corrosion resistance (especially with the DLC coating) and easy to sharpen.
Deployment
- Very easy, the over sized thumb studs work like a charm and the flipper works great!
solid steel pivot (it's not hollow)
perfect centering
large finger choil allows a lot of access to the thumb-studs
What you get
- an AMERICAN made knife for under $150 using premium materials with one of the best warranties out there (under $100 if you get a blemish)
pros
- lanyard hole will easily accommodate paracord
- Ergonomics
- Price
- Steel
- Handle material
- Build quality
- it's cool
- everything else
cons
- The clip can shred your pocket.
Comparison pics with a BenchMade Griptilian and victorinox recruit
Griptilian closed
Griptilian open
In hand pictures
Regular grip
Dagger grip
In hand closed
Other side
BLACK BLADE!
SATIN BLADE!
Cheers!
-Kirby
