While doing my nightly practice of "click-clicking" my Military with my left (dominant) and right (weak) hands, I noticed a very strange sound when opening the blade slowly with my right hand.
Upon closer examination, I found out the culprit: the right side of the blade, about an inch from the tip, is scraping at the inner G-10 handle. This happens when I exert thumb pressure on the hole prior to opening. I also noticed that, when closed, the blade is not perfectly centered anymore on the handle but leaning way too much to the right.
I checked for blade play and sure enough its there. Holding the blade tip with my one hand, and the handle with the other, the blade moves when sideway pressure is applied. This happens when the blade is locked open and when halfway closed.
Linerlock locks up solid still, though. But I think the pivot pin loosened up considerably.
Have I abused my Military? Well, apart from 30 solid spine whacks and CQBs with fish, chicken, beef and vegetables at the kitchen, I haven't used mine for anything much.
I carry my Military pivot end down inside my left rear pocket and when I sit down I exert around 150 lbs. on it's handle and pivot. Maybe this caused the uni-lined G-10 handles to flex and the pivot the loosen?
I think I have to tighten the pivot screw and see if this solves my problem.
Questions:
1/ What torx size do I need to adjust my Military's pivot screw?
2/ Do I need to loctite it after adjustment?
3/ Have any other Military men out there experienced this?
Thanks for any info!
Titan
PS Excuse my explanation; English is not my native language...
Questions:
Titan
