I went to Home Despot today to pick up a 5 gallon bottle of Dihydrous Monoxide for the office DiHmo cooler, and while i was walking the aisles in the tool department (hey, i'm a guy, i'm genetically predisposed to check out the tool department
) i looked at their laughable selection of "knives", about the only decent things there were the Leatherman tools
as i scanned the cheap Sheffield knock-off knives (a Buck 110 clone, and a Spydie-esque "tactical" folder with a thumb-oval hole and CE blade, i saw a "Hawkbill" blade folder, looked like a cross between a linoleum knife and an Opinel, and it was cheap, $8
i figured "what the heck", worst case, i'd have a beater i could use for all the stuff i wouldn't dream of doing to my *good* blades...
i got it into the car, and slit open the clampak with my Jester, and pulled the knife free of the packaging....
i kept my standards *low* for this knife, it appears to use standard carbon-steel for both the blade, and the liners, the wood handles appear to be plain wood, no stabilized wood or fancy weather-proofing here, in fact, even in it's *sealed* clampak, i noticed a few spots of surface rust on the sides of the lock release well near the lockbar lever
the lock release lever is located towards the rear of the knife, much like a Buck 110, lockup is solid, *NO* blade play, the lock notch in the tang of the blade appears reasonably deep, and the blade appears to lock positively, it resists normal pressure to cause the lock to fail, but make no bones about it, i have no confidence in the lockbar on this knife, as far as i'm concerned, it's *cosmetic* only, i'll treat this knife like a slipjoint, and assume the lockbar *will* fail....
time to thumb-drag test for sharpness....
.....Geez, i've handled sharper *BUTTER* knives....
the paper cut test was equally pathetic, it's 2 3/4" blade could barely cut apart a standard sized Post-It note, and it produced a very ragged cut through paper, the actual edge bevel was pretty bad, uneven grinds on both sides, dings in the blade right out of the factory sealed package, tiny oxidation spots on the edge bevel...(this is an *unused* knife, mind you) the *WORST* factory performance of *any* knife i've used, heck, even my Buck Metro with the crappy 420J2 bladesteel was sharper out of the box...
Since i was looking for a crappy knife to test out how sharp i can get it on the Sharpmaker anyway, i'm not *too* dissapointed in it, this was more an experiment than anything, i *bought this knife *expecting* it to get loose with use, have the lockbar fail under "heavy" use (like cutting cardboard boxes
) and corrode, i bought this blade with the sole purpose of *abusing* it, i *want* to beat on this one to see if i can get it to fail
overall, i'd rate the knife in factory condition the following way;
Fit and Finish; 2 - rust spots around lock bar, pieces of lint embedded around the edge of the wood scales, rust spots on the metal bolsters, blade slighty out of center when folded, lockbar is cosmetic at best (treat this one like a slipjoint)
Lockup; 8 - surprisingly solid lockup for an $8 knife, absolutely *no* horizontal or vertical play, we'll see how long that lasts under hard use though...
Ergonomics; 5 - nothing to see here, move along, your basic, low-end folder, not uncomfortable, mind you, but nothing special either
Sharpness; 1.5 - uhh......they *did* sharpen this one, right?.... uneven grinds, wavy bevels, tiny oxidation spots in the edge bevel itself, it's like they didn't even *try* to sharpen it....
Overall rating (factory condition); 4
i wasn't expecting much from this knife, and i got *exactly* what i expected....
pics tonight when i get home
