- Oct 10, 2018
http://www.atlasknife.com/product/hellfire-forge-cast-prototype/
It's a prototype hellfire with blown burners and a cast body (Plicast LWI 24, according to the site).
Despite the fact that it has 2 burners, I'm hoping that I can hit HT temps because it's forced air.
https://imgur.com/a/7EaO3lM
I have a couple questions about this forge though.
1. According to the FAQ, "Your burner is too far into the chamber. The tip should not be visible in the chamber". Where should the burner be in relation to the chamber? I saw another thread from awhile back that said 1/4" behind the wall, but that was for the mini forge with a venturi burner. Does the same apply for forced air?
2. What is the best way to light it for the 1st time? I found this guide but I'm still a little confused. http://www.rayrogers.com/forge_lighting.htm There's the valve on the propane tank and the red valve on the hose to adjust pressure if I understand correctly. So the propane tank itself should be full blast while the red dial is open just enough, correct?
Thanks to Charles at Atlas forge, and to Stacy for those threads about forced air burners. This forge is really well made and I think it's going to be very versatile as my skills grow.
Edit: I also see from the pictures at Atlas forge that the blower should be more to the side. That's a quick fix. I had just put it together right quick to see it.
