- May 23, 2015
I won the auction for this Queen #22 Barlow the other day for way less than $50 which I felt was a great deal. When I got the knife in hand it had no tang stamp just a patent # so it's a 61 to 71. The knife has saw very little use if any never been sharpened. It has sawcut delrin covers and what I believe to be 440c stainless What makes this knife so interesting to me is the construction. In my research I found that Modoc ED had purchased the same type knife in 2011. He did a great job in explaining the way the knife was built in the thread for this link.
https://www.bladeforums.com/threads/queen-steel-22-barlow-just-arrived.804459/
Here is a quote from Modoc ED
"What makes this knife unique is the way it is built. The body of the knife is an elongated casing with the bottom and front open while the spine and rear are closed. There are slots in the closed top edge of the casing. There is no spring pin to attach the spring to the casing. Rather, the spring is inserted through the rear slot in the closed, top edge, of the casing, fitted to the blade tang in the usual manner and fitted to a shoulder on a piece attached internally to the closed, rear, end of the casing. This causes the spring to be leveraged to the solid edge (back) of the casing. That's kind of a simplistic description but you should be able to understand it by looking at the picture of the back of the knife."
My knife was a presentation knife for a 2 year safety award according to the blade etch.
MY KNIFE
HERE ARE THE PATENT TECHNICAL DRAWINGS.
MY KNIFE
