That would tick me off. I would assume this counts as "defect". Check out the below. I'd call them up if others in the forum say that's abnormal.
http://www.spyderco.com/edge-u-cation/index.php?item=10
After looking and messing with it its actually noticeable and i used my torx set to tighten things up to the max and it wont come out. Thinking maybe of asking to exchange it for a spyderco military with the liner lock? What do you guys think of that?
Are you saying you tightened it all the way and now it's not opening? You can strip the torx screws if you go too tight. As long as you didn't damage it I would imagine spyderco should fix if you sent it in.
It's defective. I would send it back and ask for another one. I have four, none have blade play.
I have had very slight side to side play in 4 out of 5 pm2's I've owned. 3 of which were brand new.
Even tightening it down more did not take it out.
I have heard this is a very common occurrence with this knife, but the play is very minimal, nothing that would effect function. If I'm not mistaken, it's do partially to the bushing pivot.
