- Jul 8, 2002
Well, it has been in the works for well over a year, but I finally got all the bits and pieces together to build my hydraulic forging press.
Here is the frame. Designed and built to sit on my work bench in the forging room. Yeah, I ran out of primer half way through.
She is about 31.5 inches tall and 24 inches wide with a 12 inch wide "working window" inbetween the uprights.
Here are some dies and spacer plates. I have flattening dies, 1/2 inch squaring dies, and 3/4 inch squaring dies. More to come in the future.
And here is the power plant. A Rexroth 5 hp, variable displacement, variable pressure, 20 gallon reservoir, and solenoid valve.
I have a 5.5 inch bore with 3 inch shaft and 3 inch stroke cylinder to do the pushing. With such a short stroke, I designed it to always operate at max stroke. That way by removing and adding the shim plates, I can vary the shut height. When I tested the pump and cylinder a while ago, I was getting about 1.5 inches of travel per second extending, and even faster for the return.
Now I just need to rmember how I had her wired up, it should be a fun little project. I can't wait to start sqashing some steel. Heck who knows, I might like it so much that I will sell the power hammer. Well, maybe not, but I bet my neighbors wish that I would.
