- Oct 9, 2002
A bit of discussion in the general discussion area on a knife for disaster situations prompted me to post pics of this one. I made this knife for myself, to use and abuse and will be making some for sale, depending on demand. This is a knife designed to be used. Inspired by the various ABS bowie-makers, and more specifically, Bagwell and Greg Covington's combat-oriented bowies. I wanted something that could chop, pry, dig, and was bigger and heavier than my other fighters and smaller utility knives. In a pinch, SD-capable as well.
8.5inch blade (NB.- STOCK-REMOVED, NOT FORGED, just so we are clear
) O1 carbon tool steel, 1/4inch thick at the spine, full height flat ground, machine satin finished, hidden tang, chisel-ground unsharpened top clip, handle - tan canvas Micarta, 416SS fittings.
The HT - edge quenched, but the spine is partially air-hardened and then drawn down with a torch to a spring temper and triple tempered at 390F. Tang is unhardened.
This one has minimal distal taper for greater heft up front, balances 1/2inch in front of the guard. The hidden tang is a full 4-1/2inches and is 1/2inch wide at this thinnest. The tang is 1inch wide at the tang-blade shoulders for maximum strength.
What do you folks think ? Thanks in advance. Jason.
