- Dec 5, 2013
Recently there was a thread about straightening warped blades during austentizing. So, I had mentioned that I would try to post a photo of my Parrot vise plate setup. I then ended up having to have surgery to remove my gallbladder and I've been down for a little while. Got back into the shop today and managed to snap a couple pics for those that are interested.
This is how it is setup waiting for a blade to go in. Both jaws are independent in 3 axes. There is a rubber band around the bottom of the jaws to hold them open and facilitate getting the blade in quickly and straight.
2016-07-10_12-10-15 by Bob, on Flickr
I just set a blade in to show how it works. I place it in right up to the plunge with the spine at the top of the plates and tighten it down.
2016-07-10_12-08-34 by Bob, on Flickr
Another angle.
2016-07-10_12-09-52 by Bob, on Flickr
And for those who have never seen this setup, this is my standard plate quenching vise. The key here is the quick release. Also, woodworker vises have a little angle in the face of the jaws so the plates need to be shimmed when you install them. I use this for all my stainless blades which I grind post HT and I also throw my carbon folder blades in here after the 8-second quench in oil.
2016-07-10_12-10-30 by Bob, on Flickr
2016-07-10_12-10-15 by Bob, on FlickrI just set a blade in to show how it works. I place it in right up to the plunge with the spine at the top of the plates and tighten it down.
2016-07-10_12-08-34 by Bob, on FlickrAnother angle.
2016-07-10_12-09-52 by Bob, on FlickrAnd for those who have never seen this setup, this is my standard plate quenching vise. The key here is the quick release. Also, woodworker vises have a little angle in the face of the jaws so the plates need to be shimmed when you install them. I use this for all my stainless blades which I grind post HT and I also throw my carbon folder blades in here after the 8-second quench in oil.
