I picked this up at a gun show a couple of months ago. The blade is marked John Petty and sons Sheffield.
The pivot pin has been replaced with steel, the pin is wider on the shield side which I think accounts for the blade sitting against the liner.
The shield reads Osmonds "Viper" Dips, a chemical company making sheep digs ( I assume for de bugging))). The company had offices in England in the 19th century, Ireland and later registered in New Zealand. I haven't found a registration date of the company that would indicate pre 1891 so the knife could have been made for sale in England.
Further inspection of the knife made me believe that it may have started life as a two blade.
The handle pins are almost all standing well above the stag scales. The front scale pin is almost level with the stag, I think these were reset first. The back pin on the shield side was set next and he hit the stag and broke the corner off (a nice clean glue joint can be seen). I think that after breaking the scale he chickened out on the rest of the pin heads all of which have ridges and the shield right near the pins.The other side of the pin sits a good 1/16th of an inch above the scale. The spring pin has not been reset and sits 1/16th above the scales on both sides.
There is always the possibility that the blade has been replaced but it fits the back spring perfectly and fits the frame and flow of the handle so I think it's the original master.
What say you good folks?
[/url][/IMG]
[/url][/IMG]
[/url][/IMG]
This picture shows the spring pins sitting well above the scales.
[/url][/IMG]
[/url][/IMG]
This one shows the blade leaning on the liner.
[/url][/IMG]
