My sebbie is now officially "mine"
alphamaniv
BANNED
After 3 months, my sebenza is finally “mine”. I have always been its owner of course, but today I took it apart and cleaned & lubed it.
My sebenza has been seeing a LOT of use lately and a LOT of pocket carry (inside a calf skin slip pouch) While I was at my computer a little while ago; I picked up my sebbie and opened it. I do that a lot, because my pocket contents go into a wooden box when I am at home and it is located by my computer. Anyway, I open it like I have done hundreds of times and something just didn’t feel right. It didn’t sound right either. I know you guys know what I am talking about. After spending so much time with a knife you get to “know” it, so to speak. I opened it and closed it a few more times, and each time, I knew that something was wrong. Then while opened, I folded it back closed with out releasing the lock! “Oh sh!t” I said. I did this all a few more times to make sure it was repeatable. I examined the knife and could not visualize any problems, so I sat down and took it apart.
This was the first time I had ever done this. No problems with disassembly (duh!) After getting the top (graphic) handle slab off, I can see the problem. On the spacer/stop pin there was some pocket lint that had somehow adhered to just the right spot. I removed this and gave the entire knife a good cleaning with one of my trusty red shop rags. I believe that you really need to take your knife apart and look at it to appreciate all the detail and level of craftsmanship in this knife. I used the CRK fluorinated grease to lube it. This was the first time for that too. I like the twist and use tip. I used the grease as sparingly as I could, just a tiny, tiny drop here and there and put it back together. I now can see why it is so easy to “crimp” that little washer, but I avoided it:) I put the screws back in and tightened them just enough. (I think) I didn’t want to strip the heads.
Now the moment of truth…I opened it up…buttery smooth and then….”click” ahhhhh..Just right! It locks up like it used too. This is one hell of a knife!
Even the Best made products need a little maintenance now and then. I guess lint is the price you pay for carrying it deep in your pockets. Some lint must have gotten in my little pouch while I was using my knife, but it’s all-better now. Thanks to CRK for making a GREAT product. If you are a new owner like me, do yourself a favor and take that baby apart sometime. It’s nothing to be scared of and it really helps you appreciate the quality of the whole package. And it officially makes it “yours”
Thanks for letting me share this. I hope I didn’t bore anyone to death.
Congrats!
I used the 'sandwich' method before, and indeed crimped a washer.
Recently I used the Chris Reeve recommended method, which is
- assemble the handles with the stop-pin screw and the back-spacer screw. Screw-down tight
- but the bushing in the pivot area of the blade, lay the washers on both sides of the blade, lube them, and slide the blade between the handles. Might take a little practice to get it between the handles, but you're sure not to crimp anything. Line them up over the hole (use the wrench for that), and put the pivot in place and screw down tight. Should be butterly smooth...
I even think I read in a post of Anne that you're 'allowed' to flick the knife open this very first time to get everything in place. I'll try to look up that thread.
Ted
See Anne's reply in this thread
http://www.bladeforums.com/forums/showthread.php?s=&threadid=127722
The handle must be assembled first and both screws tightend. Just comfortably tight (this applied to all the screws!). The blade assembly (blade, pivot and 2 bronze washers) is then inserted between the handle slabs. If it will not go in, you do not have it assembled correctly. Do not loosen the handle screws off. Once the blade assembly is in the handles, line up the pivot hole and insert the pin. The allen wrench can help you line this up. Tighten the screw into the pin. Flick the knife open once and you are ready to go. This is the only time flicking is advised!
Anne
Awesome story alphamaniv. Not boring at all, just reassured me. I just ordered a Large and Small sebenza both with partial serrations. Can't wait to get them.
post a pic when they show up:)
My Lrg. Sebbie needs an internal cleaning and I have avoided this b/c of reading of problems crimping the washers. I may just have to give it a shot now.
TBG - don't be afraid to dissemble the knife. Even if you should fail to put it back together correctly, just send it to the shop for a courtesy fix,
They did this with a Mnandi that I had troubles putting back together - crimped washer.
TGB - Aha! I understand. One possible solution - Get another sebbie so that if one is in the shop, the other can be in your pocket.
Yep, the Sebenza is one heck of a knife. I went to Solvang this weekend to the custom knife show that they have every year and I talked to Chris and I even met Anne! What a pleasure! Bad Guy- I have a large Seb that was customized by Tom Mayo and I have to say that that has to be my favorite. Great knife and great company! I have a blue mammoth ivory Mnandi on order. That one is gonna be sweet!:D :cool: ;) :p :)
