My second foray into axe making, this time a bit bigger!
I just completed my second axe. This is a 2-1/4 pound head on a 29” (functionally more like 28”) haft, intended to be a light and nimble utility axe.
In a desire to have the best possible steel for the bit, I used the same 8670 steel at HRC59 as my previous axe (https://www.bladeforums.com/threads...conventional-adventure.1759724/#post-20143760). It’s a fairly similar steel to 5160 but is even tougher allowing me to run it harder for better edge retention without sacrificing edge stability at thinner angles. I made the rest of the head from 4140 intending on leaving the poll hard. The heat treat procedures for 8670 and 4140 are close enough for the entire head to be hardened at once.
That’s all conventional enough, but not having access to a forge I had to use a highly unconventional method for fixing the bit to the body of the head. I chose to TIG weld it with ER70S-2 filler rod, using a pre- and post-heat protocol commonly used for 4140. I had considered ER80S-2 and 309 filler rods, but I didn’t want the poorer ductility of the ER80S-2 or the stainless of the 309.
After welding I did all the shaping on my belt grinder prior to heat treat. That part was a little unpleasant, but not too bad using a 12" contact wheel. One good 36 grit ceramic belt was all it took (but that belt was shot by the time I was done). Prior to rough grinding the head weighed about 4.5 pounds and after it was a full two pounds lighter. I cut the eye by chain drilling around the perimeter with a 1/4” twist drill in my friend’s CNC mill (which is currently not healthy enough to mill the eye) and adding a slight taper with a die grinder and a carbide burr. I normalized the head 3 times and then hardened it by heating it to 1525˚F and quenching in oil followed by two 2-hour tempering cycles 400˚F. At that point I just needed to clean up the surface, sharpen it, and hang it.
The haft is hickory heart wood, chosen because I love the darker color of the heart wood more than the lighter sap wood. I was in a bit of a rush to get moving on it so this time I did all the shaping on my belt grinder. This makes an obscene amount of dust but is a phenomenally fast way of precisely removing material around multiple compound curves.
Comments and critique are always welcome and please feel free to ask any and all questions that you may have.
EDIT: added more photos
that is some really nice work OP!
I see you shot for HRC 59. do you have any opinion about harder (HRC>55) HRCs in axes?
I don't have enough experience with different axes to comment with any authority. The one thing I will say is that as long as the bit isn't chipping I prefer to be on the harder side. The downside is that it becomes more difficult to sharpen with some tools like cheaper whetstones and files. As for this axe, I heat treated a test coupon of 4140 welded to 8670 to check that the weld would survive the quench and that the hardness would end up correct. The 8670 side measured at roughly HRC 59 so I'm assuming this axe ended up similar given that it used the same protocol.
I have read that older (American) axes tend to come with a bit at a higher HRC.
I've been very happy with the 4140 felling axe at 52HRC and o1 carving axe at a higher HRC, albeit I have yet to use either :( soon, soon :rolleyes:
I'm looking forward to the o1 carving axe, but don't know what to expect with the edge
Wow. It’s amazing what you can do without a forge. Looks great! No idea what to expect for how long a TiG weld to last- maybe the life of the tool.
if you do this kind of work without a forge, imagine what you could do with one. Any chance we could crowd source a forge for this industrious fellow?
