Hey all,
Pitdog's recent thread on survival knife concepts had me wanting to post this. It's not a concept, because I've already made it.
The full tang blade is about 7" long and 1 3/4" wide. It is 154CM steel, 3/16" thick, flat ground by me and heat treated by Paul Bos. Handle is green canvas micarta with stainless steel tubes that I flared into the handle. The sharpened back edge has very fine serrations that are at depth across the bevel so you just sharpen it like a non-serrated blade. I left the flats pretty much as cold rolled. Took it all to 600 wet sand and then glass bead blasted for the finish.
I also made and hand stitched the sheath. The pocket holds a Doans magnesium firestarter and striker, also 154CM and heat treated. The gray rectangle on top of the firestarter is a diamond credit card sized EZ lap that I cut in half lengthwise and (look closely) bent one end, about 3/8", to a 90 degree angle to make it easier to pull out and hold while using. It all nests together and slides into the pocket nicely.
I made it 8 or 9 years ago, so it's seen some use and I like it. So, without further ado, here it is:
[/IMG]
[/IMG]
And this last one is the love of my life. 2 years old and the boss of the house.
[/IMG]
Thanks for looking. If I get a good response, I might post pics of other knives I've made.
lukus
lukus
