- Jul 7, 2000
I wrote this to e-mail to a friend who just got his Sharpmaker. I figured I might as well post this online as well. Please add your own tips.
Here are some tips that I have collected over time from using my Sharpmaker. Ive found some of the tips myself and some have been taught to me. Hope some of this can be of help to you.
For a while I always went from step #1 through #4 on every knife. While this might make for an edge that will shave its not always the best edge for the knife. If you are not familiar with the 4 steps as outlined in the manual they are as follows:
#1. Corners of gray stones
#2. Flats of gray stones
#3. Corners of white stones
#4. Flats of white stones
Step #1 will give you the coarsest edge which has the most micro-serrations. This edge is great for really rough cutting on rope or cardboard. The toothier edge will saw more. The cuts produced by this edge will not be as clean and dont try to shave with it! This edge will not be good for whittling or very fine tasks.
Step #4 will produce a shaving edge. This edge is best for fine tasks and the smoothest cut. This edge, however, might slide right off of coarser mediums.
#1 and #4 are at opposite ends of the spectrum with #2 and #3 being less extreme versions of #1 and #4 respectively.
Spyderco recommends using the 30-degree slots for back beveling and the 40-degree slots for the edge. This is fine on your average knife. You can also use the 30-degree slots to form the entire edge. This will produce a sharper edge, which will cut more aggressively. Since it is thinner, however, it is weaker and will not be well served for chopping or extended hard use. So how do you decide what edge angle to use? Go by these decisions:
1. What will the knife be used for?
If the knife will see hard use for long periods between sharpening, then stick with 40-degrees. If your knife mostly does easy chores or you like to sharpen it a lot then try a 30-degree edge: I think you will be pleased with the increase in performance.
2. What steel is the blade composed of?
Harder steels will obviously hold that thinner edge better. Dont chop though! You dont want to chip out a thin, hard edge. I use the 30-degree setting on my CPM440V Spydercos due to their hardness. Softer steels will roll easier and therefore a thinner edge will deform. Use the fatter edge for softer steels.
3. What is the blade/edge geometry?
I like to use 30-degrees on my full flat grinds such as my Lum Chinese folder. A thinner blade is great for a thinner edge: might as well match up your angles. Dont even bother trying to put a thin edge on a thick blade: it will not perform well. Stick to the fatter angle on tanto blades or other big boys.
Now match angles with coarseness: fatter edges will probably need more coarseness to cut. Thinner edges can be more polished since they will glide through mediums easier.
The Sharpmaker is meant for sharpening, not reprofiling! The gray stones are not coarse enough and you will be trying forever. If you want to reprofile an edge, go for the tip from Shmackey: clip sandpaper onto the rods. Find some silicon carbide sandpaper and decide how coarse you want it. Clip it onto the rods with binder clips to make sure that you are reprofiling at the same angle you will use to sharpen. Thanks for the tip Shmackey!
Serrations are a whole nother issue. Stick with 40 degrees on serrated knives. Use the corners to get in and out of the serrations. The flats can be used lightly just to get the tips of the serrations. Usually stick with the white stones unless you are working with really hard steel.
A big warning: dont ever let the tip of your knife slide off of the rods repeatedly! This will round off your tip. I like to stop just short of the tip on each stroke and then take care of the tip later.
You can even use the white flats like a strop. Just lightly draw the knife up the white flats a couple of times. This will raise a wire edge. I keep my Gunting at a 30-degree inclusive angle with a wire edge for self-defense. The hair on my arm just runs away from this thing!
I cant really think of anything else right now. Hope this helps.
