- Jul 30, 2004
I have designed my own ideal EDC multitool well Ive drawn a bunch of diagrams on paper as an attempt !!
Mixed a few ideas from all the other tool manufacturers and come up with some ingenious
new ones on making things adjustable to purpose without extra bits being carried also added a few functions which are just another use of the same blade ! (I like keeping my fingernails tidy
Size (approx LM Wave/Charge)
100mm Long
32 mm Wide
21 mm Thick (is that too big ?)
Features
10 blades Differing thicknesses with 6 blades on left side, 4 on right side
Thick (3mm) Outer Casing for internal and removable tools
All Locking Blades - both at 90 and 180 degrees
One Handed Opening Main Blade - using stud not hole
One Handed Flip Opening Pliers
Compound Leverage Pliers
Spring Loaded Pliers
Replaceable Wire Cutters for Pliers
RATCHETING Bit Driver
GLOWING - Tritium Capsules embodied into casing
Tools
Pliers Head
- Blunt Head Pliers
- Regular Pliers
- Angled Pliers (adjustable hinge on the base)
- Nail Extractor
- Wire Cutters
- Hard Wire Cutters
- Crimper
Blade 1
- Main Clip Point Blade
- Cutting Hook (on the back edge)
Blade 2
- Curved Serrated Knife
- Belt Cutter (as above!)
- Wood Saw (on the back edge)
Blade 3
- Large Scissors (spring loaded)
- Nail Cleaner
Blade 4
- Cross Cut File
- Metal Saw (on the edge)
- Fine Detail File (on other edge)
- Diamond File (on the back)
- Blade Sharpener (file can be removed from tool to touch up the knife etc)
- Nail File
Blade 5
- Philips 0 & 1 & 2 & 3 Drive (yes all on one blade ingenious adjustable head ! )
Blade 6
- Flat Head Driver 3mm-7mm (again, yes all on one blade ingenious adjustable head ! )
Blade 7
- Can Opener
- Bottle Opener
- Cap Lifter
- Wire Scraper ?
- Wire Bender ?
Blade 8
- Heavy Duty Chisel
- Strong Crate Opener
- Scraper
- Wire Stripper (adjustable)
Blade 9
- Adjustable Wrench
- Sharp Awl (on tip of wrench)
- Punch
- Scribe
Blade 10
- Ratcheting Bit Driver (will take normal size bits
Contained Within Outer Body
- LCD Panel with Time, Temperature, Altitude etc (watch battery powered - strong perspex covering glass panel to prevent damage)
- Ruler (Inches & Cm's)
- Light Hammer (extra strong area on edge of body)
- Small Flashlight (Tiny watch battery powered LED)
- Lighter (Piezo Electric with tiny fuel supply)
- Compass (12mm wide, liquid filled)
- Magnifying Glass (small, sliding out from within case so wont get scratched)
- Mini Spirit Level
- Tiny Phillips Head Driver
- Tiny Flat Head Driver (on back end)
- Blunt Sewing Needle (hole in Flat Head driver)
- Tweezers
- Tooth Pick (on back end)
- Pen (Fisher Space Pen Type Refill only)
- Straight Pin (on back of pen, with safety cover ! )
- Quick Release Lanyard Attachment
- Removable Belt Clip
Any Comments/Criticisms !!
I went for Blunt headed pliers as I find them more useful than the needle nose variety on most Multis and it gives a bit more room inside the tool for the other blades
Would having the back edge of the 2 knives used as a Cutting Hook/Saw cause any problems I often put pressure on the back of a blade when cutting !
The Wire Stripper is all enclosed and cuts down all around the wire to strip properly not the usual sharpened indent on a blade !
The mechanism on the adjustable Drivers and the Ratchet is quite neat but might reduce the amount of force I can put on them same with the angled head hinge on the pliers
The Lighter fluid is safely contained and will not leak !!
And there is a safety on the ignite button so I can't accidentally set fire to my pants !!
Ive been reading about new plastic compound materials which have the strength of steel but are a fraction of the weight, so hopefully it won't be too heavy although it might be a bit too thick ??
Anyway Im only dreaming and doodling !!
Copyright 2004 by "Perfectionist"
......thanks Bob
100mm Long
32 mm Wide
Features
Tools
Pliers Head
- Blunt Head Pliers
- Regular Pliers
- Nail Extractor
- Wire Cutters
- Hard Wire Cutters
- Crimper
Blade 1
Blade 2
Blade 3
- Nail Cleaner
Blade 4
- Cross Cut File
- Nail File
Blade 5
Blade 6
Blade 7
- Can Opener
- Bottle Opener
- Cap Lifter
- Wire Scraper ?
- Wire Bender ?
Blade 8
- Heavy Duty Chisel
- Scraper
Blade 9
- Adjustable Wrench
- Punch
- Scribe
Blade 10
- Mini Spirit Level
- Tweezers
