- Nov 17, 1999
Hello folks,
A few days ago I recieved my first busse in this far away corner of Europe. After paying the mail dude the 25 bucks taxes the customs had put on, I opened up the package and saw a whole lot of plastic.. yep, Ken does pack his stuff good
After some digging I found a greenish codura thingy with two eyelets.. seemed like I found the lower part of the sheath of my Busse Steel Heart 2 E. I inspected it closely, found that the knife is absolutely wonderfull in the hand, great balance, great feel.. truly something I never felt before. The edge seemed like new, but wasn't razor sharp anymore. Not really a suprise, afterall, it is a secondhand busse.
Then I inspected the sheath.. someone had tried to glue the kydex insert to both sides so the blade couldn't be inserted beside the sheath - I suppose for fast drawing and resheathing, I alway look at the sheath when resheathing. Now technically that isn't such a bad idea, but the dude - NOT Ken, he bought it from someone else for me - used some glue that doesn't harden, kinda like epoxy, but then the resin only with a tad of harder. OK there was work to be done here.
But first.. INFI being known for it's working nature, I went out to the woods behind the house. Now this is where a busse shines.. wood.. chopping.. working.. I took a 5 meter oak tree apart - we were gonne build a pond there anyway - , about 6 inch diameter fresh hard wood to cut down. After the first swing, you immediately feel the power of a busse.. the penetration depth and the ease of chopping were nowhere near a comparable knife in the size class, even bigger knives were not even close. However.. I did the excact same thing with a khukri I made with a convex ground 5160 with a zero-edge, and that one chopped deeper, but then.. It's twice the blade size, 4 times as heavy and has a recurve. Needless to say I was impressed. After I chopped the tree to meter-long pieces to burn up, The busse wasn't shaving -it never was in my hands - but it would still cut paper easy. The khukri on the other hand still cut, but nowhere near as smooth as the busse.. the edge had a few dull spots especially where the sweet spot is to chop. You know.. it cuts paper for 2 inches, chokes for a few mm, cuts for 2 inch, chokes again..
Both responded well to steeling, and both got to about 90 % of their original sharpness. The sap had seriously discolored the khukri, enough for me to go to the buffer, while the steel heart had a few spots were the coating was coming off near the edge, almost the whole blade was flattened coating. Not excactly a pretty sight, so while buffing the khukri, I also buffed the coating of the blade of the steel heart - this coating is a LOT more resistant that other coatings.. I figured I would spend 15 minutes at the buffer.. I stood there for well over two hours
- Now it's a satin finished blade, which I personally prefer since it doesn't seem to be any rust problem.. and it slices better too
OK, back inside I started working on the sheath.. it defenitely looked like poorly mixed-non-hardened epoxy, I removed as much as I could, then figured I needed a way to make the insert stay inside. I also made the opeing hole in the kydex a tad wider, I'll probably make a full kydex sheath in a few weeks. I used double sided tape to cover the entire sheath, inserted it with some trouble, but then it stays in pretty solid. I also removed the latch and turned it around, I suppose the original owner was a lefty.
Overall I am very impressed with teh quality and workmanship in this knife, it is close to unbelievable what this INFI can do. For some reason my leatherman wave feels right at home in the pouch, it has smooth steel surfaces (the edges of the handles for steeling) and a diamond file for heavy reprofiling or coarse edges. This combo is defenitely my first choice for my survival dropping in the center of France, in July.
However.. I have a few questions too for the Busse folks :
1. The mods I did - I am a knifemaker and I buff barehanded, so I keep it cool during buffing - do they void warranty ?
2. Is there such a thing as warranty on the other side of the world (for example Benchmade it takes 30 $ to ship it there and 50 to ship it back plus like 25 taxes = just about a new BM )
3. Are there any better blades if any out there for survivalists like me or just happy campers ?
4. the combo leatherman wave - busse steel heart.. you think that is a good choice ?
5. The mods I did.. do they press down the price bigtime ( modify a spydie and you cut the newprice in half) ?
Thanks, I'll post some pics lateron.
The pics have arrived ( the butt is excactly like new, only it didn't fit my scanner)
Lemme know what you think.
greetz and take care, Bart.
