My weekend fun
Hi mates,
Just have some freetime today. No work, no worry and mind is clear, wife is also not around, feeling energetic – a precious chance for me to finish this khukuri of mine. And right after I have finished it, I would like to share these experiences with you guys.
Making a knife always brings me enjoyable feelings though the knives I made are not beautiful yet. I came across the khukuri in 2008 and I started to love it then. Before, the Customs in my country was still naive, I could manage to buy few pieces from KHHI. However, the Customs is becoming more rigid and I can no longer buy anymore. I found the traditional way in making khukuri is interesting. In mid Jan this year, an idea pop out “the Customs sucks, why don’t I try to make a khukuri myself?”. Then the project began.
From the pictures you posted in this forum, I chose some of my favourite designs. I traced the outline on computer, print the outline in paper, then cut a draft on a piece of metal like our kamis usually do. Then I had a local blacksmith make a raw blade for me at the price of $15 each blade. The blacksmith does not know a thing about khukuri. I had to inspire him with a lot of pictures. Out of the 03 blades he made, I just can choose one to work on the finishing. He still charged me full price for the two failing blades but that’s okay. It’s R&D cost. :) Below is one of the 02 blades that I don’t proceed to finshing.
I don’t have a belt sander to shape up the blade so I used the bench grinder to profile it. At first, I’m really scared. Totally, I didn’t have any experience in how to hold the blade, how to make the V shape on the spine,..etc. But along the way I grind, I started to gain confidence with the bench grinder. It works quite well. Here are my tools:
The hollow part (chirra) on the blade is still not there yet. The blacksmith is just familiar with the flat blades and they don’t know how to do it. Me too!
For the stripes on the blade, the chisel I bought is not hard enough for the job, and my hammer is just 100g which cannot drive the chisel much into the blade. Then I just park it there.
What I’m still not happy is that there are some tinny holes in the raw blades. This is left when the steel are pressed during hammering. The holes are deep and I just can leave them as is. If I shave them off, the blade cannot be kept flat. Next time, I will ask the blacksmith to have about 2-3mm thick buffer to the raw blade.
For the cho, I used a crescent (half moon) file to file it into shape.
For the convex edge, I was making a thin edge profile as a balace between chopping and clearing bush. I tried some chops and it worked quite well. I also had a light chop on steel water pipe with this blade. The blade survived well, however, when I chopped a steel sheet (1mm thick), the blade had a small chip. Probably, when the contact surface is small and the impact pressure is high, it’s easy to get chipped.
The hardest part to me is the bolster. I tried to cut a piece of brass from 0.9mm thick sheet stock, then soldered it into a ring with a gas torch. But this was not a good solution in my case,with my tools, at my level. Another option for me is to cut it from 28mm diameter brass pipe, then hammer it into shape. The drawback is that you can see the bolster is getting wider towards the cho and spine.
For the handle, I made it in the form of rat-tail tang. I did not peen but I used a nut-and-bolt solution for this. The wood I bought from the local carpenter. This is a similar kind of hard wood to Dhar (in terms of functions). In Vietnam, we use it to make the wheels for cow cart. This hard wood can survive sun and rain with minimum shrink, and people just call it cart-wheel wood. Next time, I will have some more angulation to the end of the handle, from the ring backwards, leaving more comfortability for the hand while chopping.
This took me nearly 4 months of weekend time off and on to finish this piece. I still need more time to finish the blade and work on the scabbard. It’s true that when I get down making the knife myself, I realised the reality of the hard work and admire the Kamis for their talents, knowledge, skills and patience.
If you mates have any idea on how to make the piece better, kindly share!
Wish Auntie and you mates all the best!
Hung
Very Nice Job, Hung! It looks very good for being self made.
Did you heat treat the blade?
And have you epoxied the handle onto the tang? This will help keep the handle on and absorb some shock while chopping. The only other thing i would do is grind the hex parts off of that cap nut before or when you finally mount it.
All the best to you also!
Hi Karda,
For the handle, the only diffence is I dont have lahah and I had no choice other than expoxy. I also add some more wood powder in for a better match between metal and wood. Next time, I will try a kind of tree gum which Vietnamese fishermen use to fill the joints between wooden planks of their boat. Assume that they are similar...
This blade is made from leafspring. The blacksmith has heat treated the blade for me. He quenched it in a water tank, not by the pitch like our kamis. Firstly, he put some salt in the bowl, pour a few drop of water, then use a stick to drag that thick salty liquid along the edge. Afterthat, he burn the blade to the proper heat then dip the edge in the tank. He uses a stone to test the hardness, totally base on his feeling and personal experience. If it's still soft he dip in water 1 or 2 more time. If too hard, he uses the heat above the forge to soften it down.
I tested the hardness with a file and the file cannot eat the blade. Assume that hardness falls above 59 HRC.
I still need an ace shape brass layer for the handle. I've thought of grinding off the hex part off the cap nut but I had difficulties in screwing/tightening it. Will explore...
Next time, I'll try to share some more information on the traditional quenching techniques that I observe / heard of in Vietnam.
All the best!
Hung
Nicely done, Mr. Hung! You have a lot of hard work in that khuk, that makes it personal and uniquely yours. I doubt I would have the patience. What an attitude, if you can't buy it, you just make it yourself!
That looks pretty good to me too, a lot better than I would have managed. You have a nice piece there Hung.
It isn't easy to come up with something like this from just looking at pictures on a computer screen.
I think it is a great looking blade for sure and your idea of using the fisherman's glue is probably a good one for the handle.
As Karda says, the gluing of the tang into the handle will really change the shock absorbing quality of the wood.
That's a great job! I kind of like the hammer marks on the blade. They give it that hand made feel which is lacking in so much stuff these days.
Nice work! At first glance, I thought customs had finally cut you some slack and let you get a pre-made one shipped to Viet Nam!
@ Karda & Warty: You are right saying that. I love the feel they create. With my experience, making this kind of rat tail handle cost me 50% more time vs the full tang, and though it’s not as tough as the full tang like the CAK. However, I’m going for lighter weight. We often go mountain climbing. With luggage on the back, camera on the neck, a khuk on the belt,… any single gram counts, so this rat-tail version can reduce weight some how for us.
@Khuku'nut: We share the same taste on the hand-made feel. Another point to share with you that at first, I wanted to keep it as black village finish coz it can reduce rust. But when I finetune the bevel, the border between black and white was fuzzy and made it look ugly. Then I had to compromise with satin finish like you see in the pix.
@CSG: The Customs are really rigid. They examine every single shipment. In Dec 2009, I shipped some small 440C blanks though USPS but got confiscated at Vietnam end. They just let go the wooden scales and bolts. Hand carry is better. I have relatives coming back from Boston this summer and already bought a ColdSteel Kukri blank for them to carry. God bless me!
Cheers,
Hung
Nice job and great pix, thank you for sharing
How wonderful that you could make a khukuri, which looks to me to be very practical and nice in appearance, yourself!
Congratulations, and thank you for sharing all the details which went into the work.
You just made my world a little larger. I am grateful.
My deep thank to Auntie and everybody for your encouragements. This is what I only can do to relieve my khukuri fever.
Can anybody share with me how to make the khukuri bolster from sheet stock? I'm still struggling with it though!
Cheers,
Hung
Inspirational work Hung. :)
Your efforts show that barricades to achieving goals can be surpassed with resoucefulness and dedication. I applaud your endeavors! :thumbup: :thumbup: :thumbup:
WOW! Hung that is nothing short of incredible considering the tools you have!:thumbup: :cool: :D I most certainly admire your perseverance in getting your khukuri finished!:thumbup: :eek: :D :cool:
