- Mar 27, 2013
So I know a people say quality control with Boker can be hit and miss but I fell in love with the look of the Boker Pipsqueak and decided to order one. Got it in the mail last week and been carrying it since then. At first, I felt like the lockup was way too early (probably 10%) so I loosened the pivot screw a little bit.
Here's the issue: When I keep the pivot screw a bit looser, the lockup improves all the way up to about %45 (which is great), however, no matter how much I loosen it, it then creates a little bit of up-and-down blade play when the knife is closed. It's not a crazy amount of play, but for $190 I don't want to have any play at all. If I tighten the pivot screw to the point where there is no play when closed, the blade becomes tighter to open and close and the lockup becomes virtually non-existent
So it's clear this pivot's construction doesn't have ball bearings or else tightening the screw wouldn't affect the blades ability to open and close, right?
I actually called the repair shop at Boker and he recommended I send it in to him to have a look at. If I send it in and he's unable to fix it though, then he'd have to send it off to Germany (for which the turnaround time is up to 2-4 months), or just place an order and replace it with a new Pipsqueak all-together.
So do any of you experts out there have any possible suggestions or philosophies on what my issue could be? For the record, the detent ball catches nice and strong, the lockup (even when early) is always rock-solid and the blade centering is perfect. This is a great knife, I'm just trying to figure out if this is some issue that might NOT require me to send the knife away to Boker...
Help?
Help?
