- Mar 21, 2020
Hi all, my blade from N690 material is after heat threatment - quenching no more magnetic.
Is this normal?
Is this normal?
how an why?I think your question needs to be re-written.
No, it doesn’t.The added Chromium and Nickle Make N690 Theoretically Non-Magnetic.
Did you Miss the Theoretically part of the Non-Magnetic...Ferritic Stainless has more Iron where less Iron is found in Austinitic SS like the 300 Series of Stainless, but there are Many Austinitic Stainless Steels. So it's not just a matter of Austinizing at a High Temperature.No, it doesn’t.
So let see if I got this Right...Austinizing at a High Temperature as Larrin suggests you change the N690 to Austinitic Stainless in the Range of 300 series which by most accounts is "Non Magnetic".you would need 300 series stainless levels of nickel to lower the austentizing point to room temp. N690 is a martensitic stainless.
Please, keep digging your hole deeper. Would you change your mind if I told you that N690 doesn’t have a nickel addition?Did you Miss the Theoretically part of the Non-Magnetic...Ferritic Stainless has more Iron where less Iron is found in Austinitic SS like the 300 Series of Stainless, but there are Many Austinitic Stainless Steels. So it's not just a matter of Austinizing at a High Temperature.
Um nickel is magnetic
Nickel, cobalt, and iron are magnetic. What you have isn’t nickel. Nickel-silver maybe?hmmm, my nickel bar stock for guards will not stick to a magnet.
It's not an on-off thing, the more retained austenite the less magnetic it is.I really interest in whatis the percentage of RA that will make martensitic stainless non magnetic?
