N690Co is not an Italien steel - it's an Austrian Steel from Böhler. You will find a lot of informations in the forums about the performance of N690Co![]()
Extrema ratio uses it but haven't heard how it compares
N690 is not the same as VG-10... somewhat similar but not the same.
N690 is substantially BETTER than 440C, no real comparison there.
N690 is an excellent steel that makes a fairly ough blade with excellent edge holding and cutting ability. I've made 100s of blades from N690 and find it to one of the best all purpose steels on the market.
ATS-55 and N690 are substantially differrent alloys... even a quick check shoud show that.
N690 is N690, it contains 1.5% Cobalt. There are not two steels, just two different ways of marking the products.
Go to Boehler's website and download the data sheet if you want accurate information.
N690 is a better perfoming steel than 440C. But you can believe whatever you want.
In our testing, 440C had better corrosion resistance. N690Co had better edge retension and would hold up better with a very thin edge. Given the choice, we would use N690Co instead of 440C unless corrosion reistance was more critical (such as he whale blade).
sal
sal
