Having a problem with Naniwa Superstone 400. Using clamp on guides for a pretty edge...no angle changes at all.
First, to establish bevel I use DMT XC, not apexing. Almost apex not quite. Move to C DMT and apexing, creating minimal burr both sides, then finishing off the edge as if this were my final stone. Will easily shave hair and bite into nail.
Wanting to refine diamond scratches I move to Naniwa Supertone 400. This stone makes my edge duller. Apex is no longer crisp. Will not shave at all, barely bites into nail.
Frustrated, I use the DMT Fine, and this brings the edge back. Easily shaves and bites into nail. I progress from there, Shapton 1000 Pro works in the diamond line up quit well. What a stone that is! (See I misspelled "quite", but I left that in there just for Rick! ... and my eclipses too ... )
So no matter the steel, and using an angle jig, the Naniwa Superstone 400 basically kills my edge, but any diamond or waterstone after wards works fine.
This happens every time, no matter the angle or steel.
I've heard those stones are softer, maybe it's rounding off apex? Doesn't feel like that tho when I am using it. I've never had issue using water stones in a diamond line up before, until this stone. Even using the Naniwa in an exclusive water stone line up, it seems to do the same. Yes, freshly lapped, and very flat. No mud either, just splash and go. Metal shavings suspended in water on top of stone. The Shapton Pro 1000 in a diamond line up works very well.
Any thoughts as to what might be going on with this stone?
Side note....last night decided to thin down a Kershaw Leek 13C26 (AEBL). Sigma Power Select II 120!!! Wow! (Keep under running water...it loads instantly) to thin, almost apex. Shapton Pro 1000 at about 14° per side to establish bevel on an edge that barely reflected light. Then Spyderco Fine Ceramic, then 0.3 micron film. WOW!!! Sharpest I've ever made a knife! EASILY would split my arm hair lengthwise, while still on my arm. The sharpest I've ever made a knife!
