A while ago, Natlek posted a method he used to make d-handles, which he called the "D-handle grinding jig". Today, I made a similar jig to see if it would work for octagonal handles. It is nothing fancy, just a couple of steel templates that are temporarily glued to either end of the handle blank, and then used as guides for grinding. I tested it out on a piece cut off from a 2x4.
Aligning the templates was surprisingly easy. I used thick superglue and once I had the template positioned in the center, I sprayed a little activator. Grinding the handle took less than five minutes and the result looks really good. I plan to make a couple more test handles with this method before I commit to making a handle from the ebony, but I think this will work well. In my previous wa handle attempts, I had a hard time getting the corners even.
