Navy SEALS's bush sword
This was an interesting project. I was contacted by a Navy SEAL who wanted a blade. He had come across my website and liked a bush sword I had made that was inspired by a Thailand machete I had seen in an article in Tactical Knives magazine. I still had that bush sword, with a neon orange paracord wrap. As we discussed things, we considered re-wrapping the handle in colors more appropriate to covert operations, but ultimately I recommended that he let me build a new one from scratch since I make my military blades a bit stouter than general-use blades. Also, he wanted the top edge of the clip fully sharpened and the original only had a false edge. I suggested the possibility of a Micarta handle on a full tang, but he liked the integral socket handle idea.
So going from my first take on the blade here:
I forged out this 16" blade from 1/4" 5160 and triple normalized it:
After eating the scale off with an overnight soak in vinegar, I ground and filed in the bevels.
After that came a triple hardening cycle in canola oil and a triple tempering cycle in my kiln.
Since this may be going into some pretty hairy situations, I took an extra step after the third tempering cycle and differentially tempered using a pair of tempering tongs to heat the spine and make it tougher. I alse drew the tip back a bit extra, with the thought that a slightly bent tip is more useful than one that's broken off in a dire situation.
Given that he wasn't sure whether he'd be carrying it into a desert place or one with more vegetation, we decided on a color scheme that could work in either place. The main wrap is olive drab and the two-strand Turk's head knots are in coyote brown. After the wrap, it was impregnated with Minwax Wood Hardener. Somehow or other, I didn't do my wrap correctly and had some small gaps between coils that I didn't see until it was already sealed. I don't think I've seen that before. So I cut off this wrap and redid it.
After that, I built the Kydex sheath for it. We decided on a digital woodland camo pattern that had enough mix of green and brown to blend well with a variety of environments. A pair of MOLLE locks and a whole lot of grommets gives plenty of options on carrying it.
After that it went to fellow knifemaker and leatherworker Luke Swenson, who's an all right fellow for a grinder guy. :D He made a leather rig with a detachable shoulder strap and carrying frog. After I got it back, I sharpened things up and got the final pictures before mailing it out.
This was like making the machete/Bowie from Predator, but a thousand times cooler because it's going to a real special forces hero instead of actors. :D
Love the blade James, and no offense to the kydex but that shoulder sheath is killer!!
I am sure your client will be thrilled!
COOL! Not my general style of blades, but that is badass and looks like it could withstand any duty!
The kydex sheath has the military look and the shoulder rig is SWEET!
Well done,
Peter
That is some great looking work.
Love the Bush Swords.
Thank y'all!
No offense at all, Ben. Luke does good work. :)
I asked the SEAL to let me know where this goes with him if he's able to. He said he would, or at least when it's gone out with him if he couldn't tell me where. :)
The SEAL e-mailed me, "Tested it out last night, safe to say that one section of the Christmas tree is decidedly much barer now. Haha" :D
I don't think I've had a bad or rude customer, but he's been the most polite. I asked him if that was his SEAL training or his raisings, and he says it's his raising. :)
I removed some unwarranted posts and any subsequent replies to them. The posts were not deleted but moved to the moderator's forum. Please continue on and I apologize for the attempt at derailment.
Jason
Thanks for keeping things civil, Morrow. If there were some unwarranted comments that showed up in this thread, I didn't even see 'em. :)
Doug - Luke's done several other leather sheaths for me and they always have been on special projects of one kind or another.
Teclis22 - Just sent you an e-mail.
:thumbup: I like the extra length which seems like it would put the choppin' sweet spot a little further out where it will have more force behind it. This is a big advantage because it means fewer cuts to get the job done and that reduces the repeated shock force to be absorbed by the hand. Hand fatigue dramatically increases the chance of accidental injury. Plus you can't work any more until you rest that hand.
Side by side use of 3 or more similarly sized large blades proves they differ in how quickly each induces shock related hand fatigue. With this in mind, I bet this blade could do a lot of work before the hand gives out. Partly because of the overall geometry, sweet spot etc., but also because the handle allows a secure grip with plenty of room to constantly vary the grip, which significantly delays the onset of fatigue. Whether going into battle or going into the woods for a long weekend, this would make a great go-to blade for actual use. Don't ferget yur foldin' knife though.
I like your analysis, HTMD. It was a bit of a challenge to build this one a bit heavier than I typically do for strength because I like a good chopper to feel light in the hand, believing that the acceleration aspect is more important than mass in the force equation. But the SEAL said it has "great balance", so I achieved what I needed to in that department.
The drop in the handle, widest part of the blade being around the sweet spot, and multiple distal tapers all are geared toward the chopping side of things.
But yeah, the smaller tasks will be much easier with a good folder or small fixed blade. :)
