neck knive thickness
how thick do you guys usually make your neck knives. also what do yo think would be the best handle material for a neck knife
. thanks
I've always felt that a neck knife should be minimalist. 1/8" thick , no handle and the tang has lightening holes .My Custom E.Boese is made of CPM154 with wharncliffe blade.
I make them in all different thicknesses. My current EDC necker has a 1/8" thick steel with 1/8" orange g-10 handles on it.
Most of mine are out of 1/16" thickness. I have some in 3/32" thickness too.
Just depends on the what you want or what someone else wants if you make one for them.
Bryan
I'm with mete,but also use 3/32"steel w/3/32" G10 handles.
Stan
Thinner the better... a neck knife will most likely have a narrower blade and thick stock will just make for a more obtuse bevel... not as good at slicing. I like 1/8" and 3/32"
I use .06", .09" and .125" mostly.
Thinner is better, especially for a neck knife.
I make a lot of neck knives and most of them are between 1/16" and 1/8" thick. 3/32" is a great thickness for most neck knives. I really only ever go thicker to make the spine better for filework.
Carbon fiber and ebony are my favorite handle materials for neck knives. I like to use lightweight materials whenever I can. Every gram counts on a neck knife. No one wants to carry an anchor around their neck.
I've found 1/8" is good for small knives. I'm still unsure of what I like better for regular sized knives, though. Where I buy steel is always out of 3/16", 1/4" is too big. I think I may stick with 5/32".
3/16" is a lot of steel, even for a pretty big knife unless it's approaching a chopper or fighter. I've seen it work in small knife too, but that takes some skill (that I don't have).
-Daizee
