- Jun 5, 2009
I've gone through a number of these and thought I had found what worked, a Coast HP4. It meets nearly all my criteria:
-slim form factor with bezel-down pocket clip;
-tactical switch (momentary or locked on);
-probably tough enough to use for impact, at least for a single encounter (and cheap enough to replace);
-single output (claimed 100 lumens, but bright enough for my purposes, an no cycling through modes to get going).
There are two problems with it. A minor one, namely that its bezel is only minimally extended from the lens. I'd prefer one that stuck out further and was not crenelated. The major one is flicker. I've noticed it since I got it and it's getting progressively worse. Battery changes have not helped.
So I'm thinking I need a new light. I need something that meets the four criteria stated and ideally has an extended but not crenelated bezel. One other problem: it cannot be made by Streamlight. I've owned at least three of them (a Batonlite, an original 3xAAAA Stylus, a Nano, and there may be a fourth I can't recall). The only one of these that didn't die spontaneously was the Batonlite, and it was a lousy light. The others died without cause as the batteries still had plenty of current.
Any ideas?
Any ideas?
