- Jun 19, 2018
Hey folks,
So as you can see in the pictures below I have a chefs knife profiled and beveled.. I spent the better part of the day hand sanding to 2000 grit and etching in ferric chloride/h2o mixture.
this was a piece of steel i got on line, and it was .15" thick and precision ground. it consists of 5160, 15n20, 203n, and 52100
I cut the basic profile, and heat treated it, then ground the bevels in.. after that i hand sanded and etched. not sure what is causing that big line running from the curve at the bottom of the tang up to the top of the spine there..
any ideas what causes this or how to fix it?
this line was not there when I received the billet, so im sure its something I did. I did not heat the handle to the same temp as the blade.. but I did have the whole blade at non magnetic for about a 2 minute soak ( steel makers recommendation on heat treat)
