- Dec 11, 2000
*Update 28 June 2021* If the thread is too long, the conclusion was that it would cost more to make the UK motor fit than to order a US motor, from the US.....
. I have now ordered such a motor and will be on tenterhooks for the next few weeks until it arrives and I get it working.
I doubt many here have had this problem, but what the heck, there is a lot of expertise here and someone might have a good suggestion.
I live in the United Kingdome and am looking to buy a new belt grinder. I don't want to DIY build one. Looked at lots of options, read lots of reviews, decided that I want a Reeder Products machine with a bunch of their accessories. Contacted Reeder and good news, they will ship to the UK!
The UK uses 240V at 50Hz and my understanding of everything I have read (which was enough to
me) is that I will at the very least be sacrificing top speed if I try to use a US spec motor and VFD designed for 220V at 60Hz. It would suck to have over $1000 of motor and controller shipped from the US and for it not to work at 100%.
The Reeder is set to use NEMA 56C, which has a 4.5" (114.3mm) location register diameter, four 3/8 clearance mounting holes on a 5.875" (149.23mm) PCD and a 5/8th shaft. The problem is that motors available here use IEC size interface, the most appropriate looking units use a B14 interface which has a 95mm location diameter, 115mm bolt PCD and a 24mm diameter shaft.
Greg at Reeder has said he can bore one of their 5" drive wheels with a 24mm bore, but while I didn't explicitly ask about machining a different interface, I opened the door and think Greg sounded pretty set that their grinder uses the NEMA56C. As the plate is CNC milled, I can imagine that it would be a PITA to do something different as a one-off.
Does leave me scratching my head on how to proceed. I did look for motors designed for the UK electrics that used NEMA interface, but such things do not appear to exist. Any advice or suggestions, whether it be on motor choice or adapters would be useful.
The alternatives I thought of to fit a UK motor were:
NEMA - B14 by Last Scratch, on Flickr
Chris
NEMA - B14 by Last Scratch, on Flickr- Get a thin ring made that fills the radial space between motor and grinder location diameters. Drill four more holes on smaller PCD in grinder chassis to use M8 motor mounting points. Holes will partially cut through locating diameters. Probably the cheapest and possibly something I could do myself
- Back the motor off the grinder by about 3/8th (9mm) left and find UK engineering company to make a full adapter plate that locates motor on one side and grinder on other, screw adapter to motor face with counter sunk M8 screws. Thread holes in adapter to line up with existing holes in grinder, maybe use M8 and spacer sleeves in grinder chassis, rather than trying to use/source 3/8-16 UNC hardware that chassis holes sized for. Problem may occur with insufficient shaft length available to engage drive wheel.
- Full rework of chassis plate, probably involve stripping down to flat plate, find UK engineering company, plug existing locating diameter and re-cut. Hope everything lines up and nothing else gets damaged. Not sure how such a large area would get plugged, but I am thinking JB-Weld might be involved
Chris
