DaQo'tah Forge
Banned
- Aug 26, 2002
I have trouble trying to grind a convex edge on my knives.
This is what I do, please read then advise:
I forge to rough shape.
I grind the profile lines (The outside edges all the way around) with 36 grit belts on contact wheel.
I grind flat on the platen starting with 36 grit, and go all the way up in belts until I don't have any higher.
I file the shoulders for when I place a guard on later.
I decide where the cutting edge will start. I mark that placement, then I begin with a 36 grit and "slack belt" grind from the marked position to the blade tip.
THE PROBLEM:
My convex edge never looks thin enough. To correct what I think is too blunt of convex edge as it dives down to the cutting edge, I push harder on the blade into the slack belt as I grind it.
However as I push harder on the knife into the sanding belt, (Blade is positioned always edge up so I can see what's going on) I have to make sure I don't dig too deeply into the cutting edge and thereby mess up the future cutting edge, so I tilt the blade's edge a bit away from the sanding belt in the hopes I can grind more off the sides first.
It is this tilting away of the cutting edge that always seems to bring the spine of the blade down into the slack belt and it starts to get sanded without my knowing about it.
All the sudden when I check how Im doing, I find that I have sanded a 'dip' in the spine.
Now I have to spend most of my time working on the other side of the spine to even out the spine taper so that one side will match the other.
Suggestions?
THE PROBLEM:
Suggestions?
