Nothing wrong with your smiths combo diamond stone unless you used excessive pressure while using it and ripped out the diamonds. If you haven't done so already clean it, dish soap and an old toothbrush works good and when you need more potent stuff to help clean it something like barkeepers friend will do the trick. Use water with it when you are sharpening if you want as it helps float the swarf.
It's more on technique than equipment on getting a sharp edge, I am willing to bet you need to work on your technique to get that sharp edge on your knives. Off hand 2 of the blades you listed have incredibly soft steel the Izula and SAK, in fact I would argue that until you get your skill up that the diamonds would be cutting too aggressively for them and would make it more difficult to put a nice edge on them. A Norton India combo stone would be my reccomendation for those as it should give you some pretty good feedback and cut less aggressively and put a nice edge on your knives. Can't comment on the vg10 as I haven't sharpened any steel like it.
On the plus side that stone I mentioned should set you back $20 and last you a lifetime. I would also pick up some compound such as some green rogue, flexcut gold, etc as long as it's of decent quality, that can set you back another $10 but also last you a lifetime. Since it sounds like you having difficulty sharpening and I will put money it's on technique you can cheat a little and pick up a DMT Aligner clamp and use that with the benchstone to help you keep a consistant angle, and as an added perk it makes reprofiling knives a lot easier and is worth it's weight in gold in my opinion. I actually prefer using the clamp on it's own with a $6 silicon carbide norton economy stone than using the entire DMT Aligner Deluxe I bought.
On strops you don't need to purchase one you can build one from MDF, leather, leather belts, balsa wood, use paper, etc the only limit you have is your mind. I used to use a piece of mousepad cut to fit on top of my benchstone and wrap paper and put the compound on that and strop. Now I switched to having a stone size block with some drawl liner wrapped around it and secured to it and once again wrap paper around it and strop. The liner set me back $1, and I am using some cheap $3 green compound which I don't reccomend and am getting some better stuff in the mail shortly. But even if you don't want to buy compound you can still strop on plain paper, belt, etc. In fact I used to strop on cardboard and I still strop on plain paper too. I hear paper that has the more brightly colored pages to it such as the cover to magazines I believe use clay in them to get that color and work good as strops in a pinch.
Here are some people who make some good sharpening videos, watch and learn. It will take a long time to absorb all the information but it will save you a lot of headaches in your future and possibly money thinking you need the better gear to get good results. My primary setup is 2 cheap $6 norton economy stones a silicon carbide and india combined with the worlds cheapest and crappiest $3 green compound with a custom strop I made that I mentioned earlier which I just started experimenting on which set me back an additional $1 for the liner. And that liner was originally bought to help keep the stones in place while I am sharpening. I can get my knives to slice and push cut newspaper with this setup (or even just one of the stones on it's own actually).
Jdavis882, I highly reccommend watching the one on off center edges and a lot of his other videos
https://www.youtube.com/playlist?list=PLB95E1C271CE6654B
MrEdgy
https://www.youtube.com/channel/UCfsHYm19KjjnUlpG8WVMZOA
Neuman2010
https://www.youtube.com/channel/UCjWBLVqZqnP9LQClOESmheQ
http://www.bladeforums.com/forums/showthread.php/963298
Also take a look at the stickies on top of this forum it's a good read. At the end of the day it's all about putting a good apex on the blade, removing the burr and putting an acute enough angle to help you cut. It's mostly technique and very little on materials. And practice practice practice, preferably on some cheap knives you don't care about so you don't mess up your nice knives. I find a cheap kitching paring knife works good due to being inexpensive and the simple blade shape helps make it easier to sharpen when you are learning. Oh and don't forget to sharpie up your bevel so you can see where you are sharpening.
