I've taken in a couple Cold Steel Arc Angel bali's for anodizing. The first came out great without issue. The second has a more rough satin finish and after anodizing deep purple, you could see in the fine sand lines at the right angle that the color was off or non-existent due to the many angles throwing the appearance off. I'm sure you experienced makers know what I'm referring to. Looks a little like pitted and lightly ozidized aluminum sometimes does.
I consulted a knowledgeable Ti. anodizing vet and he basically agrees with the assessment that it is a surface finish issue. Regardless I am ordering some cold method multi-etch and niobium anode before reattempting.
In the mean time, I think the best course of action in surface prep would be to wet sand the handles. Only thing is I've never sanded on Ti. and am not sure which grit would be best for final outcome / appearance. I know that torch coloring Ti. can put off vaporized vanadium which is bad, but is the Ti. dust any more harmful than steel? If so, will a regular 3M mask from Lowes suffice?
Thanks for any advice / tips guys.
