go with a delta 14" platinum edition, it costs $800. it comes with a closed stand, 1hp motor, rip fence, mobile base. definetly worth the money. don't go with harbor frieght you can't buy any parts for it, and they aren't made like delta saws. if you can afford it after you buy it, if you buy the delta, buy carter guides made for the delta, they improve resawing accuracy greatly. i ordered mine just before the new year, but they haven't gotten them to me yet. also get power twist plus v-belt. it's a link belt that reduces vibration in your saw, which increases the accuracy and smoothness of the cut. and get steel machined pulleys.
i have a RIGID 14" bandsaw, it's is a fantastic saw, costs $500, very versitile, and built well, and i recommend it, but you have to buy carter guides directly from carter, if you want them. you can buy it from home depot.
the only other band saw i recommend is JET 14" saw, model number jwbs-14csw. i've heard jet equipment to be ammong the best along with delta and a few others. it's $554, i suggest buying the moble base made for it.
the guides i wrote about are called CARTER guides, they are the best in the industry, and will improve your resawing and ripping accuracy. if you want carter guides for a delta or jet saw, you can order them from tool crib. but if you want them for a RIDGID saw you need to call CARTER to have them ordered.
you can order all these, except the rigid saw and guides from tool crib (1-800-635-5140)
CARTER's number is (616-451-2928)
the rip fence i plan on buying is the fasttrack bandsaw fence, it's machined from aluminum, and supposedly one of the most accurate on the market, i'm going to buy a drop stop and micro adjust with it.
you can buy that from woodcraft at 1-800-225-1153.
i hope i didn't sound like an advertisement, but i know my bandsaws and i believe in these saws and accesories.
