- Oct 19, 2011
I do some motorcycle racing. To keep the tires up to temp when on standby I use tire warmers. the switches are made of cheap plastic. They get stepped on and run over etc. and end up getting smashed. I repaired it once and it worked great but this time it cannot be fixed. I would like to replace the plastic switches with durable metal switches similar to the bottom image. The function of the switch is not ON/OFF. It is WARM/HOT. So it is on all the time but there is a high and low temp circuit. See images below. I stamped the inside of the case with a "w" for the warm side and an "h" for the hot side of the switch. Can someone please suggest a switch that will replicate the function of my current switch? What is the switch called and how should it be wired to get me the high and low temp circuits?
