I bought the WE kit after I got my first RL knife with a D2 blade. I've used the WE to sharpen it, but can't seem to get a really good edge.
Here's how I set everything up.
1: I clamped knife roughly center of the using the bottom stop, and noted the position with the provided ruler.
2: I used a sharpie to shown the angle of the edge, then adjusted the rods to that angle. The angle ended up being between 22- 24*, so I set the rods to 24*.
3: I started sharpening with the 100 grit blocks. 3 passes on one side, then the other side with decent pressure. I probably did this 8-10 times with each grit. I continued this process all the way up to 1000 grit, then used the strops to polish the edge.
Here are my issues.
I was able to get a nice even edge up to the point where the blade curves to the point. There, the edge/angle gets wider. It's hard to explain, but you can see more of the cutting edge there, than on the flat portion of the blade. Also, I am killing the point. Kinda rounding it. I think this is probably because I'm pushing the block past the point too hard.
Here's a picture.
After I sharpened it the first time, it felt very sharp, but wouldn't cut paper cleanly, or shave my arm hair-usually how I tested knives in the past.
I resharpened it a few days later because I wasn't happy with the edge. This time I set the rods to 22* and repeated the process from 100 grit up.
Again, it's not sharp like I feel it should be. What am I doing wrong???
Should I be wetting the blocks?
Am I using too much pressure?
What's the best angle? Maybe that's off?
Any other tips would be appreciated.
Sean.
Here are my issues.
Here's a picture.
Sean.
