I'm tryin' to attach a magnetic knife bar to my kitchen wall. I need
two strips of sheet metal to use as "straps" to screw or bolt the bar to a peice of flat wood, which will then be screwed to studs in the wall. I can't seem to find pieces of sheet metal of the right dimension. The two pieces need to be exactly 3/8" in width, by 6" long. My wife used my tin snips to make a Guinea Pig cage and ruined the edge, so I can't cut sheet metal to the desired width.
The gauge is not critical, a gauge similar to plumbers tape is fine. Something that will bend to wrap around the spacers in the bar. Attached is a photo of the magnetic bar.
My plan is to use the thin strips to wrap around the spacers between the two bars and screw or bolt them to a backer board. This way the surfaces of the bars will be completely clear to contact knives over the full length.
Can some good samaritan with a sheet metal shear cut me a couple of strips? I can send a self addresed stamped envelope. Again, I want two strips 3/8" wide by six inches long. Black steel is fine (I'll paint it) or stainless.
